News
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
Storage virtualization tools refined
Published on April 02, 2005
IBM, Network Appliance Inc. Read more
Microsoft releases Vista programming tool betas
Published on January 18, 2006
Microsoft today released updated beta versions of its programming tools for building Web services and workflow-enabled applications on Windows. Read more
Intel to develop notebook platform for Chinese students
Published on April 14, 2005
Not just the IT industry has noticed China as a growing and important market. Read more
Latest Reviews & Articles
Intel's Core i7: Blazing Fast, But Crippled O/C
Published on November 03, 2008
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
  Tom's Hardware Forums » Homebuilt Systems » New System Build » Building 2 New Systems. Please help.
Word :   Username :
Bottom
Author
 Thread : Building 2 New Systems. Please help.
Profile: stranger
More Information
First I wish to thank ever one in advance. I have been
reading the forums for a few weeks now and have
gathered a lot of good info.
This will be my first new system build, actually my first and second.
I am planning on building two pretty much identical systems.
I would like the two systems to be well rounded. I wish to be able
to multitask, play games, watch TV, spreadsheets, word processing,
programming, etc, etc....
I myself love to tinker with things and plan on learning to over clock.
Below is what I have come up with over the last few weeks.
I am looking for any and all suggestions or alternatives.
With a monitor and a few other accessories what is listed below prices
out really close to what my budget will be. I am shooting for about $3000 plus
or minus for both systems.
If I can trim a little here and there without
sacrificing performance or potential I can get a nicer monitor or some other accessories.
Heres is what I have so far.
Antec P182 Gun Metal Black 0.8mm cold rolled steel ATX Mid Tower Computer Case
I would very much appreciate some other suggestions, possibly something without
a front door and more front USB connections.
Antec True Power Trio TP3-650 ATX12V 650W Power Supply with Three 12V Rails 100 - 240
Is this PSU overkill? Is it modular or again do I care?
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
2 x 4MB L2 Cache LGA 775 Quad-Core Processor
Will I automatically receive a processor with g0 stepping or do I really care? Do
I need to purchase a better CPU cooler?
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM
DDR2 800 (PC2 6400) Dual Channel
EVGA 512-P3-N802-AR GeForce 8800GT Super clocked 512MB
256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card
I know that there are several flavors of the GeForce 8800GT some harder to
find then others. Which one do I want?
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM
16MB Cache SATA 3.0Gb/s Hard Drive
SAMSUNG Black 20X DVD+R 8X DVD+RW 12X DVD+R DL
20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM
48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner
Microsoft Windows Vista Home Premium 64-bit
Thanks again.
Related Product
Not smart enought? Try Harder!
Profile: stranger
More Information
I think you have made so good choices here It will be a very good ALL ALL round system. Firstly the antec case is very good case for the price but maybe consider a Full tower case for extra space this space provides better organization of cables and components provides better airflow and more ports for fans etc this would be a good benefit to you if you are considering overclocking,
Power supply will be fine not over kill, Its good encase you want more HDD or Bigger Graphics card but with your system you will need at least a 550W/600W So you are good there.
Motherboard seems fine maybe see if there is a model up from this one with 2x Pci-e Just for upgrade options to sli.
Processor is very good, this model is more revised and runs with less power and is able to run at higher temperature to its earlier one by 11 degrees celcuis i believe correct me if i am wrong :) this will aid you in overclocking. lso if you are over clocking you WILL need a better cooler maybe a ZALMAN they have a good range also cooler master i have a GEMINII that i am very happy with.
Ram seems good 4gb is a big over kill at the moment, maybe go for the crucial ram or cursair ram
Graphics card is fine its a good choice
HDD is good
Writer is good
Vista is good maybe consider Dual booting with XP for older programs but its not that crucial... If you do do that then partition your drive into three at LEAST 20GB to vista and 10GB to XP. then the rest will be to your programs this has many benefits.
Hope this helps.
greetz South Africa
Profile: Forum Veteran
More Information
The psu is semi-overkill if you don't upgrade the cpu/gpu at all in the future. I'm sure you will.
No, you don't get G0 unless you look/ask for it. Neweggs don't. G0 can take more heat so it can overclock higher than non-G0.
Get the 8800GT for around $250. The rest are overpriced. For $300, you can get a GTS512 after rebate.
Profile: stranger
More Information
This is great. Where else can you get expert advice for free. Thanks all for your input. I will post another update after considering all of your suggestions. If anyone has any input on an LCD monitor 22" to 24" I would love to here from you.
Profile: stranger
More Information
24" Is very big the 22" i find is perfect size but it depends on your preference. Go for Samsung or for BENQ both provide in my opinion good proformance and value samsung esp. if you are gaming get a 2ms response one its worth the extra.
More Information
I think you should get the GTS512 or better yet ATI HD3870 X2 (faster & cheaper than ULTRA) for 22" - 24" resolutions if you want to max things out in games.
Profile: stranger
More Information
Stick with Nvida hey they are way more powerful then later on you can Sli them. But all you need is that GTS512 or GT512 for now. As much as i wanna support ATi they aren't as powerful. So stick with nvidia the resolutions are very good and the quality of graphics top notch!
Google Ads
