CamelToSiSss
5
hello, :hello:
i have amd athlon xp 2500+ 1.8ghz normally it runs at ~40C.
is it possible what cpu temp can reach 128C then i overlock it from 1.8ghz to 2.1ghz? :O
CamelToSiSss
5
but you know problem is what i checked temp with speedfan before oveclocking ( i dont know exactly wich temp is cpu http://www.ipix.lt/desc/81808666/ ) and temp2 was around 40C, after overclock temp2 instantly reached 128C
CamelToSiSss
5
another example: then i checked temp with Everest before overcloking cpu temp was in program and was 40C, then i oc its gone - no cpu temp. maybe i didnt have to worry about cpu temp? sry bad english
