Hi folks,
I need you opinion on my (first) self-built system:
Here's my rig :
CPU: Intel Core2Quad Q6600 2.4 GHz 8 MB L2 cache 775
VGA Card: Geforce 8800 GT 512 MB - Gigabyte or ASUS (which one would you recommend??)
Motherboard : Asus Maximus Extreme - (I plan to use 2GB DDR3, and later add more - should I get some other mobo??)
Memory : Kingston KHX14400D3K2-2G Kingston 2GB 1800MHz DDR3 Non-ECC CL8 (8-8-8-24) D
HD1 : Seagate Barracuda 7200.11 1TB SATA2 7200RPM 32MB Cache
HD2 : Seagate Barracuda 7200.11 500GB SATA2 7200RPM 32MB Cache
DVD-Writer: I have an IDE on my old PC - can I use this on the IDE of ASUS maximus extreme?? or should I get a SATA DVD-Writer (if I should, I'd prefer ASUS, or maybe LG - what would you suggest??)
For the following I need your suggestions:
I'm not planning to use water cooling, and overclocking would be a small possibility.. so which of the following, and what should I get:
Case : ??? I have no idea... What would you recommend, if possible mini or midi. I'd like to have the fan on the front and then left, as the PC will have a wall on its right side. And earplug socket and usb on the front would also be fine.
Cooler: Arctic Cooler Freezer 7 Pro (or, does one come with the case you suggest, and I don't need to add any cooler??)
Power supply : ??? I have no idea...
The price ranges change a lot for cases and power supplies. What I'm looking for is something decent, which won't cause problems, which is very silent (I'm not planning to, but might overclock in the future), and possibly not too expensive. Please do suggest "the XXX is the best, but you can also have the YYY, in which case you would be deprived of ZZZ" etc...
In addition to this... do I need anything else?? cables etc. come with their respective products, right?? I have read something about thermal insulation paste, but would prefer keeping the original past on the case/cooler or where ever it is, than make my fingers sticky applying it (am very awkward with such hand work).
any help appreciated. many thanks in advance..
o.m.
Here's my rig :
o.m.
