personally i would put the FSB at 400, set the memory in 1:1 ratio, cos 1066 MHz is 100% unneeded unless ur watercooling lol.... then drop the multiplier to 8 or 7 for a start. nice cooler best choice! no prob installing it?
and wow thats one hell of a graphics system.... 2 4870's own GTX280's with ease
^or if you're really lucky with a low VID chip, or you lapped the IHS/cooler you could try nad get 3.6 with a 400MHz FSB and x9 multiplier! lol not very likely but tell us how it goes!!
OK I got it to run stable at 3.0GHZ at stock 1.3 Volts.
I went to go try to 3.2 and it was to hot - I thought my cooling would def be better then it is. I of course had to up the volts, was going a step at a time, but the CPU was running 65-65-58-58
Right now idle at 3.1GHZ the temps are 43,45,39,40. (Idle) at load they are 60-60-58-58. Right now it is summer where I am and when not home about 85 and when home keep the room at 75.
I re-seated the heat sink and still same temps.
What can I do to improve?
Message edited by TheDJ08 on 08-01-2008 at 04:07:53 AM
Is it a Q6600 G0 or B3. I assume those are load temps at 3.2G. What program are you using for temps? I assume you tried to run it on auto Vcore and it failed.
At 3.2 load I was getting temps of 65-65-58-58. At 3.1 load I am getting 61-61-56-56
Yes Auto VCore had failed and I am using core temp.
You should try Real Temp. You will find that the temps are 5C lower, due to a 5C lower Tjmax. IMO the Tjmax of 95C in Real Temp is more accurate because Unclewebb actually did testing with a temp probe to come up with that number. That should give you temps of 60-60-53-53 Prime95 @3.2, which IMO are acceptable. Even the 65C are technically OK, but a little warm for my taste. The large differential between cores 1,2 & 3,4 are probably due to the weight of the cooler. If you want you can put a slight upward pressure on the cooler with your hand and see if cores 1 & 2 come down a little. For a lot more information on temps your should read CompuTronix's temp guide.
Message edited by Zorg on 08-02-2008 at 11:01:37 AM
Yeah real temp is showing 5 degrees lower - that is good. I know others have had a lot better temps then what I have - some @ 3.5 w/ a load of 45 or so
I will try what you said and also look at that guide - thank you.
