I just built a new system and am having a problem. Hope someone can help. This is the build...
Gigabyte GA-P35-DS3P Rev 2.0
Intel Core 2 Duo E6750
4x Crucial Ballistix 1gb BL12864AA804
BFG 8800GT OC2 512MB
Silverstone Strider ST60F 600W PSU
+3.3v / +5v / +12v1 / +12v2 / +12v3 / +12v4
33A / 24A / 18A / 18A / 18A / 18A
Drivers are all updated.
Everything seems to run fine except after playing Crysis for around 20-30 minutes the screen freezes and gets all pixelated and red. I get the same problem when I run the Ntune stability test.
The videocard fan is running fine. The case isn't hot inside. I'm not getting any heat alarms. Not sure what to do.
,Thanks in advance for the advice.
