Hd6670 installed help
ronshelley
Hello,
Just installed hd6670 Inspiron 531 desktop. Now everything on my screen is oversized and slightly distorted. I set my dpi to minimum -and reduced icons to small...still oversized and fills my 22" screen. Is this normal?
Go to the Control Panel and then to Appearance and Personalization and change your resolution settings.
The Appearance and Personalization area contains Personalization settings (for desktop background, colors, screensavers and themes), Taskbar and Start menu settings, the Ease of Access Center, a Folder Options area that allows you to setup how all folders on your computer are displayed, a utility to add and remove fonts and the Sidebar properties to add and configure gadgets.
Dark Lord of Tech
Retired Moderator
