Tom's Hardware Forums » Homebuilt Systems » New System Build » Help with building (cheap) gaming system <£500
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Help with building (cheap) gaming system <£500
Profile: stranger
More Information
Need some advice on the following:
ATI HD 3870 XT 512MB Gigabyte 256bit Dual DVI PCI-E Graphics Card
AMD Athlon 64 X2 5600+ (2.8GHz) AM2 2MB L2 Cache
Gigabyte GA-MA69VM-S2 690V AM2 VGA 8 channel audio RAID mATX
2 x 1GB DDR2 800MHz PC2-6400 240pin Generic
DVD±RW/DL/RAM LG GSA-H55NBAL 20x  IDE
2 x 80GB (RAID 0)Seagate ST380815AS  SATAII 7200rpm 8MB
2 x 160GB (RAID 0) Seagate ST3160815AS 7200RPM SATAII 8MB
Coolermaster Elite 330 Black Mid Tower Case
Casecom 500W 12cm Fan - 20+4pin, ATX12v
£479 inc VAT
Is this a decent spec for a gaming system?
Is it worth having the RAID setup?
Related Pr oduct
Profile: stranger
More Information
... cough.
Gosh, i love ATI
Profile: addict
More Information
i personally am going for an HD3870/50, with the E2140, cos i need to finance an OS and monitor... i would suggest you try and shift yor budget to fit in a Wolfdale processor, IE, the 8400... cos the AMD processors atm aren't really worth it, 'less you want to get a phenom, IMO
Profile: stranger
More Information
That AMD was the cheapest AMD CPU with 2MB cache, costing £85 with fan.
The intel will cost ~£130, around 50% more.  Ideally I'd prefer to stay below £500.  I could afford it if I get rid of the RAID setup...?
Profile: addict
More Information
You're overkill on hard drives...you'll get better performance with 1 drive for Windows and 1 drive for games AND getting an 8800 512mb card (GT or GTS) with the money saved.
Have you looke into the Gigabyte P35 board, an e2160 (overclock to 3.0ghz) and some better RAM?
I've never heard of that brand of PSU...what's the amps on the +12v rail?
Message edited by Noya on 01-24-2008 at 12:36:30 PM
Profile: stranger
More Information
The PSU is just some cheap one that got good reviews:
+5V - 38A, +12V - 17A, -5V - 0.5A, -12V - 0.8A, +3.3V - 28A, +5VSB - 2A
Wouldn't RAID 0 make games/windows load faster?
8800 GT/GTS is about £30+ more than the ATI HD 3870 XT is the difference that huge between them?
Profile: Ancient Poster
More Information
Get a good power supply. It can wipe out your entire investment.
The one you chose does not have enough power. You need 21-23 amps on the 12v rails at a minimum.
Top Tier PSU:
http://www.tomswiki.com/page/Tiere [...] ngs?t=anon
Scruze my English!
Profile: nimble knuckle
More Information
That PSU will not run that system. +12v amps is much too low. http://ati.amd.com/products/radeon [...] ments.html
Get like a 80gb for Windows, and a second drive for data. Will perform almost as well as Raid, and save some money.
I know what I know, and I don't know what I don't know.
More Information
I would stay away from generic memory. It can cause a lot of errors which are hard to detect. Since you are on a budget, I would get Kingston. Other good brands are Patriot, Corsair, Crucial, OCZ. Take a look at the venor's qualified memory list on the Gigabyte site for your motherboard.
Scruze my English!
Profile: old hand
More Information
4 HDD in RAID 0... You are ASKING for data loss.... Get 2 larger ones and try them in RAID 1. WHEN 1 dies you'll be thankful.
Profile: stranger
More Information
The generic mem has got good reviews.  But branded is only a few £s more so will go with that.
But good branded PSUs are expensive...:
Coolermaster IGreen 500W PSU £50 T_T
It's two pairs of HDs in RAID 0. No RAID, just 2 HDs and Coolermaster PSU, gives £444 total.
£56 remaining, use for external USB drive for backup?
More Information
The Coolermaster Igreen is OK. 33a on the 12v rail. Gets decent reviews. http://www.driverheaven.net/review [...] lusion.htm
If available, the Antec Earthwatts 500w is better quality, and is usually at a good price. After rebates, they are only $50 in the US.
You could always drop down to the 5000+ Black Edition processor. Performance is not much less, but the price is usually much better. Requires less power and creates less heat also at stock speed.
Profile: newbie
More Information
Its better to be thankful you spent the extra money on a decent PSU than to buy a crap one and take all your components with you.  10% of your build for a nice psu isnt that bad.
Profile: stranger
More Information
I see your point kustomizedstang.
5000+ Black processor...?  I don't want something too weak.  Ideally want a processor that can encode/resize a 120min video in 120 mins or as close as  possible.  I don't know much about processors in that respect.  I just picked AMD cpu because they are cheap and the 5600+ was the cheapest one with 2MB L2 cache.
Add a reply
Google Ads
