My 8600gt from evga isnt working with my asus m2v motherboard the fan works but i get no image on my monitor.
I have 2 gigs of ram
one 80gig hd and one 200gig one
430 power supply.
video card says it only need 350 watts. I have another video card in right now and it work.
(Also i know this 8600 works.. put it in another computer
Sponsored Links
What is the "other" card you are using to make it work?
Reply to raven_87
Some dimand one one...from office depot
Reply to sk8tboar
Well thats really not helping;
Is the line coming from the PSU to the GPU clean?
Reply to raven_87
if it's like most 8600gt cards, it doesn't require power anywhere but the pci-e slot itself.
Reply to sepayne21
apologies, I'm thinking of the GTS...
that said; what is the other motherboard you tried the 8600 in?
Reply to raven_87
My brother couldnt tell me the exact name of the board... hes kinda far away and not much of a computer nerd. Its some Nforce sli enabled board i believe is what he told me.
When i put the 8600 in my computer the fan runs on the card.. but when i start up i get 3 beeps and no video input.
Reply to sk8tboar
These beeps are the computers way of telling you what is wrong AMI Bios beeps.
3 short beeps is the bios code for bad memory try taking the ram out and reseating it.
Mactronix
Reply to mactronix
The memory should be fine. I kept it in for the diamond graphics card. Its only when i switch the 8600 in when i get the beeps
Reply to sk8tboar
You need to delete old drivers then shut down computer reset cmos add new card then fire it back up. It will work if the card is good. Your cmos is just looking for the wrong info until you reset it.
Reply to roadrunner197069
You motherboard has integrated video. That may switch itself on when you change the graphics card. You may need to disable it a second time.
Also if you are switching cards from ATI to Nvidia, you should run Driver Cleaner.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 8600 gt (Need help)
There are 767 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
