Tom's Hardware > Forum > CPU & Components > CPUs > New E8400 build help
Forum CPU & Components : CPUs - New E8400 build help
I recently just put together my pc and have an E8400 with the stock intel cooler. It seems to me after reading different posts that my processor might be running alittle to hot. The temp is around 47 at idle. I have not oc'ed it at all and I am using an antec 900 so airflow should be good. Any help would be appreciated?
http://img252.imageshack.us/img252/2261/corezp6.png
Sponsored Links
Its fine, mine runs @ 45 idle so dont worry
------------------------------ Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
I have not tried Core Temp on my E8400 machine. I'm at work right now and will see its readings when I get home. However, Gigabyte's utility, my BIOS, and SpeedFan tell me it idles at 14-15C.... either your running a little warm or my this thing is piece of **** that doesnt work.
Reply to nforce256
But yeah, you don't need to worry about CPU temps unless you're passing the 60 mark.
Reply to nforce256
Thanks for the info
Reply to Dirtdog15
15C is about 60F, which is unlikely with the stock cooler.
Reply to 96Firebird
I just used a few different programs and they all read 13-15C at idle. Under load, it shoots up to 32C during UT3 and Prime95 pushes it upto 44C. It may be unlikely if your room temperature is 70+ degrees. I don't have central heating in my room and the temperature hovers around 60-65F. Maybe that helps it keep cool along with the 4 case fans I have.
Also, I believe its called SpeedStep? When the system is at 13C, CPUID is reading the multiplier to be 6x opposed to the 9x under load.
Reply to nforce256
I'm not sure I buy your temps... 60F = 15C, and I doubt your cooler is keeping it under room temp. That's according to http://www.onlineconversion.com/temperature.htm.
My 8400C @ 3.8GHz idles at 27C, and with 2 copies of Prime95, it hits 41C. That's using a Scythe Ninja cooler. Normal room temps are around 20C. When I downclocked it to stock speeds, it would stay at 27C even after 5 minutes of 2 copies of Prime95.
Clint
Reply to CNeufeld
BTW, my temps were measured using Speedfan, and on an Asus P5K-E motherboard.
Clint
Reply to CNeufeld
Clint
I concur.
It's against the basic laws of Phyiscs for his CPU to be running at 15c unless his room is quite a few degrees below 60f. And I seriously doubt that is the case.
I don't doubt they are reporting that figure.
It's just that the figure being reported is not correct.
------------------------------ If its good in theory but not in practice,
its not good theory.
Reply to zenmaster
I finally got CoreTemp working with my system (Vista 64) with this link:
http://forums.erodov.com/local_links.php?catid=18
When Speedfan and AsusProbe measure 40C for the CPU, CoreTemp measures 51C/43C for Core 0/1 respectively. When I shutdown the two copies of Prime95, the temps drop down to 40/40 for CoreTemp, and 27 for AsusProbe/Speedfan.
Clint
Reply to CNeufeld
That sounds about right to me... considering you are running it in a cooler room.
Clint
You forget that you are overclocked... Obviously you are going to be running much hotter... Dont forget that he has speedstep enabled. That basically lowers the voltage and multi to make the cpu virtually off! I believe his temps because it makes sense. If his operating system is at idle and his cpu is super uderclocked than there will be minimal if any heat produced.
Reply to hughyhunter
The E8400 also uses 2-3watts at idle.
------------------------------ 3.8ghz Pentium D loading at 43C? What?
Reply to jbj190
There might be "minimal if any" heat produced, but he's not going to be under room temperature, unless he's running some form of refridgeration. 13C = 55F = 5 degrees less than his lowest room temperature mentioned. 44C under load sounds about right, though.
I didn't forget I'm overclocked... I even mentioned that when I ran stock speeds, the only real difference was it ran consistently at 27C, never increasing from that even under full load with 2 copies of Prime95 (one per core). And I also had SpeedStep enabled for both my scenarios.
And just for the record, I'm not accusing anyone of lieing or deliberately misleading anyone else. There seems to be a lot of confusion about the E8400 temperature sensors, particularly with the P35 motherboards (of which I have one).
Clint
Reply to CNeufeld
What are all using to monitor temperatures? I am getting mine Tues and want to see what I'll be getting as far as temps. I have a thermalright ultra-120 extreme on the way too.
What settings are you using for speedstep in bios?
Oh yeah... if i'm not mistaken if you change voltages to manual for cpu in bios speedstep will not change your voltages from that position to idle.... but yeah I really think that he wouldnt go below room temps too... maybe 5C above room temps at idle without overclocked voltages.
There's a problem with the temperature sensor on E8400/8500. Intel tool care of this problem on Yorkfield, but on Wolfdale.
Anyhow, Intel specified the maximum temperature for Wolfdale core to be 72.5C, therefore, anything below that should be fine.
Reply to mngdew
There are 1132 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
