I find that Rosewill is not all bad. When the product is good, its great, but the sames true in the opposite. I find the only thing that I do not like about that PSU is that there is no 6+2 or 8 pin pcie connectors, and Rosewill is not the most prestigous brand. If there is a good reason for that PSU in particular, most people on this forum forget the needs of the poster, then go ahead and get it. If you want it for the pretty lights then do not look twice, the power supply is the main part of your system and should not be based on looks, but the chance it will fry the rest of your system.
Rosewill is on tier-5 ("Do not buy" ) of the PSU listing at http://www.tomswiki.com/page/Tiere [...] gs?t=anon. Since that listing was last updated, however, at least one Rosewill PSU received a "recommended" review at Jonnyguru, so specific models may be ok now. With so many known good choices out there though, I personally would not buy Rosewill. Your call.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Tier 3, but a goodie, 36 amps on the 12 rails. BUT, if you do plan to Crossfire in the future, grab that pc power and cooling one mentioned, do not skimp out on the PSU, it's the most vital component in your system.
The antec neopower is made by seasonic. I have the actual seasonic version, SS-500ES, which is identical internally, and is only $70 at newegg. Awesome P/S, as all seasonic's are.
@OP:
See:
http://www.xtremesystems.org/forum [...] p?t=108088 for PSU tire listing. I recommend you get a top tire PSU listed there. I would personally go with a Corsair 550VX/520HX or PC Power & Cooling Silencer 610. If on a budget get the Antec Neo Power 500 .
