Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help, my friend is driving me nuts with his new home build.
Forum Homebuilt Systems : New System Build - Help, my friend is driving me nuts with his new home build.
I am an Intel person. I would rather OC a e2160 to get 3ghz than pay for it. He really doesnt want Intel and he says he doesnt want to OC.
So now I am left with helping put together a machine. On the list down below, he isnt willing to change the case or get anything less than a 8800GT 512mb vid card.
This will be a gaming/home machine. This is a list I put together. He wants cheaper. I know I can save about $60 on the HD and maybe $20 with a boxed amd x2 6000 cpu that comes with a stock fan as opposed to the Freezer Pro..
Any suggestions?
RAIDMAX SMILODON ATX-612WB Black SECC STEEL ATX Mid Tower Computer Case $79.99
GIGABYTE GA-M57SLI-S4 AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard $99.99
EVGA 512-P3-N801-AR GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video $249.99
SeaSonic SS-500ES ATX12V 2.2 / EPS12V 2.91 500W Power Supply - OEM $69.99
AMD Athlon 64 X2 6400+ Windsor 3.2GHz Socket AM2 125W Dual-Core Processor Model ADX6400CZWOF - $159.99
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) $53.00
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive $119.99
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM $27.99
ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler - Retail $19.99
------------------------------ Q6600@3.6(9x400)Lapped Abit IX38QuadGT,TRUE 120 Lapped,Vista Ultimate 64bit,Gigabyte HD 3870 OC'd to 860/2250 w/ Zalman Fan,4x2GB G.Skill PI-Black,CM690 w/ 5x140m 3x120m fans,Idle 28c load 42c-Corsair HX620w
Sponsored Links
Go for the 6000+ instead of 6400+ and you can drop down to a 320GB drive, that should save some money with the least amount of performance degrading to the system.
Reply to Gravemind123
get some different ram, 53 dollars for 2 gigs is about 20 dollars to much imo and corsair aint the best anymore, look at cruical for 2 gigs
Reply to monste4321
- 0 +
Tell him to build his own.
Saves a lot of friendships.
------------------------------ I am old enough to be your grandfather.
It was born a Dell, it was made into a computer by StevieD
Reply to StevieD
I agree.
Tell him to come here and he can decide what he wants with the help folks here.
If you want to help assemble do so.
However, if the stuff does not work as well as he expects or breaks, you will get the blame.
Even good parts don't always work.
------------------------------ If its good in theory but not in practice,
its not good theory.
Reply to zenmaster
- 0 +
ha-ha, I can tell you read the boards here.. You defended yourself for posting a build with AMD!
Reply to grieve
Tell him to not skimp on computer parts, puts too much pressure on you to bring down prices, then you have to ask people on tomshardware forums for suggestions.... :)
Already looks really cheap, what does he want? A Miracle?
------------------------------ Intel C2D E8400 OC @ 3.6GHz.--TRUE 120 W/ Scythe S-Flex 28.0dB.--EVGA 8800GTS 512MB.--ASUS Maximus Formula X38 (0907).--Crucial Ballistix 2x1GB DDR2 4-4-4-12 @ 800Mhz.--WD 150gb Raptor.--Corsair 620HX Modular PSU.--Antec P182 Case.-- Vista 32bit.
Reply to Beurling
Unless that CPU is OEM, you don't really need a third party cooler. Especially since he doesn't want to OC at all. Granted it's only $20 but still, it's $20 he can save.
Since he wants that particular case, the only other part that you can easily cut down on is the HDD. Assuming he doesn't have a huge library of music/movies etc. you can get a 250GB for about $70.
Reply to fueled_by_ramen
- 0 +
Hi guys,
Seems I made him out to be a bit worse than he is....... He was just mining me for the cheapest 3.0ghz machine for gaming.
We made some tweaks, got the price down some. Here is the list of what he just purchased 10 mins ago.
RAIDMAX SMILODON ATX-612WB Black SECC STEEL ATX Mid Tower C $79.99
GIGABYTE GA-M57SLI-S4 AM2 NVIDIA nForce 570 SLI MCP ATX AMD $99.99
EVGA 512-P3-N801-AR GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail $249.99
SeaSonic SS-500ES ATX12V 2.2 / EPS12V 2.91 500W Power $69.99
AMD Athlon 64 X2 6400+ Windsor 3.2GHz Socket AM2 125W Dual-Core Processor Model ADX6400CZWOF - Retail $159.99
mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 996527 - Retail $45.99
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $69.99
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA $33.99
MASSCOOL G751 Shin-Etsu Thermal Interface Material - Retail $4.99
Subtotal: $834.90
Reply to xringx
@OP: Smiler to a friend that I have who is still stuck in AMD fanboism (he quotes 2005-2006 benches :lol: ). I built a E2180 based PC with a 8800GT (he has the same card) and it pwns his X2 6000 on pretty much all the benchmarks. :lol:
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
There are 550 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
