News
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
Overclockers Push 8-core Skulltrail To 6 GHz: Dual-socket Overclocking Confirmed
Published on April 18, 2008
Las Vegas (NV) - When Intel released its Skulltrail platform , the main focus of this extreme computing platform was on overclocking capabilities. Now it has been pushed to 6 GHz by overclockers. Read more
Magazine for Overclockers Reaches Issue #2
Published on October 17, 2008
Issue #2 of the world's first magazine dedicated to overclocking and hardware news has just been released. Read more
Intel locks overclocking features
Published on June 19, 2004
Rumors, that Intel's new chipset 915/925 platforms do not offer much of a FSB overclocking margin, have been circulating for some time. As Tom's Hardware Guide was able to confirm, Intel went one step further: The chip giant adjusted its hardware to prevent any overclocking. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
  Tom's Hardware Forums » Overclocking » General Discussions » overclocking a Q9450 help
Word :   Username :
Bottom
Author
 Thread : overclocking a Q9450 help
Profile: journeyman
More Information
guys, i am currently running a new system and am looking to overclock the cpu for the first time
Q9450 2.66 ghz stock
asus p5e deluxe
4 gig ocz reaper 1066 ram
zalman 9700led cooler
antec 900 case
4870 gpu
sata 500 gig hdd
can you guys give me a basic guide to overclocking this cpu by raising the fsb?
any help appreciated
lawrie
Related Product
Noob? Currently on Sabbatical!
Profile: Honorary Poster
More Information
It all depends on where you wish to over clock the thing to.
Basically, the thing to remember is how you get the speeds. For the processor speed, its the FSB x the CPU Multiplier. (x8 in your case.) = Speed. So its 8 x 333 = 2.66.
And once you place the RAM in sync mode, it'll be the FSB x 2 = RAM speed.
So basically moving the FSB from 333 to 400 would make it 400 x 8 for 3.2 Ghz, and 400 x 2 for 800 Mhz RAM, and you tighten the timings as well as you can for running it under speed.
The speed doesnt matter, once it goes over the FSB, so thats why people run it in sync. The FSB is the Memories pathway everywhere else. So it can only take data equal to its size from and to the RAM.
Running the RAM over it, can slow it down, as it has to break the data up and send the rest on the next cycle, and then re assemble it.
Anyways, you will have to change a few other things, like voltages, once you decide where to over clock to!
Also, DL the program, Core Temp, or Real Temp, and look for your VID, then list that here, will ya??
Thanks!
--Lupi
Profile: journeyman
More Information
thanks for the response lupi, i was kinda looking on more of a guide on how to do it. can anyone help?
Profile: journeyman
More Information
ok i have looked at my VID, it is 1.1000v in stock. the freequency is currently showing 20003.7 mghz (333.95 x 6)
does that make it easier for u guys?
More Information
No, not yet. Although it would be totally awesome if that is it's true VID! So I wish for the best!
Now go into the Bios and disable C1E Under CPU options, as well as Speed step, and EIST, then re check with core temp or real temp!
If it's still that, It's on to helping you!
--Lupi
Profile: member
More Information
I wish I had a VID of that...haha. Mine is 1.250. Voltage right now is 1.3 for 3.2GHz.
More Information
Most are over 1.2000, and a few under 1.2000 but over 1.16.
A single one has been near the lowest, 1.1125.
So I am hoping to see a 1.1000 and then have someone who wants to really see how well it can do!!
I have my fingers, toes, and circuits crossed!
--Lupi
Profile: nimble knuckle
More Information
If it is indeed 1.10v, you havea a very good chip to overclock :).
More Information
Hehe, you have peoples attentions now, it appears!
By your CPU speed and multiplier it's obvious you have one of em on! Now we need to see just what the enabled option is adjusting.
For instance, on my p5k-e wifi, it cant change the voltages dynamically downward when load line calibration is enabled, so I get the multiplier drop, but no voltage!
So it is possible with the CPU options enabled to still have a 1.1000, the odds of getting that VID in the first place are very slim to none, hehe!
So, in conclusion: One can still hope!
--Lupi
Profile: journeyman
More Information
sorry guys im pretty useless with computer stuff, if this is amazing it might be lost on me. can someone actually explain to me what vid is and how it will impact the oc
Profile: journeyman
More Information
haha okay, so probably now **** it, turned off speed step and it is 1.2125
now better for some help?
My name is... V3NOM... and i like cheese.
More Information
lol what a shame....anywho, i suggest upping the FSB to 360 ish FSB, prime95 testing it then upping it again to 400, upping the voltage slightly each time if necessary. (that is if it fails prime 4 or 8 hours small FFT's...) read some overclocking guides seriously theres tons of em out there...
Profile: journeyman
More Information
ok so i raised the fsb up to 375 and it is clocked at around 3 ghz, will i need to increase fan speed or will it do this automatically depending on system stress. how do i get my hands on prime95 and how will i know if i need to up the voltage?
Profile: journeyman
More Information
ok bump guys, i have increased the fsb to 400 which takes my cpu to 3.2ghz, im confident with my case, ram and cooling this will be fine, i am going to run prime 95 but i need to know if i need to manually increase my fan speed (9700led) or if i need to increase my voltage before i try this (currently VID 1.2125v) - any help would be greatly appreciated, u guys have helped stacks already
lawrie
Profile: journeyman
More Information
i need to know what settings to run prime95 in also, do i just use the small and run it for 8 hours, or do i need to set a timer etc. my cpu is idoling around 40%, what temperature is acceptable if i run this program
Profile: journeyman
More Information
n°1769602
08-06-2008 at 01:05:52 AM
