Hello everyone! I have recently begun expereiencing boot problems with my computer. Upon restart, my computer hangs directly after the memory is checked. The system hangs at the same point with each reboot. The dialogue present on the screen at the time of the freeze is:
Press F2 To Enter System Configuration
Press F11 For Boot Menu
Dual Channel Memory Mode
Then the system hangs. There are no beep codes to indicate particular device failure. I've tried accessing the BIOS, but the first line of dialogue just changes to indicate your selection, and then hangs at the same spot. If I start the system without memory installed, I get the predictable beep codes. If I start the system with the hard drive disconnected, the previously described behavior still occurs. This makes me think it is a bios or motherboard problem. I can't access bios settings or the o/s for troubleshooting, and I don't have a post card. If anyone could provide any insight into this situation, I would be greatly appreciative.
Some information about my hardware setup follows:
ASRock 775V88+ Motherboard
3ghz Pentium 4 Socket 775 Prescott Core Processor
PC3200 400mhz Corsair Value Ram 512MB x 2
Seagate ATA-5 120 GB Hard Drive
No floppy drive
Thanks in advance.
No floppy drive
Thanks in advance.
