Hi,
I am building a new system. It's been about 4.5 years (a P4 system) since i have done this and see that things have changed a bit since then. This system will be used for gaming, photoshop, tiny bit of 3d studio max, minor video editing, and then just your general browsing wordprocessing stuff. so basically some of everything. so here is what i plan on getting:
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/product/product.asp?item=N82E16811129021
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Retail
http://www.newegg.com/product/product.asp?item=N82E16819115017
ASUS P5E LGA 775 Intel X38 ATX Intel Motherboard - Retail
http://www.newegg.com/product/product.asp?item=N82E16813131219
Patriot Viper 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/product/product.asp?item=N82E16820220293
EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16
http://www.newegg.com/product/product.asp?item=N82E16814130312
OCZ ModXStream OCZ780MXS ATX12V / EPS12V 780W Power Supply
http://www.newegg.com/product/product.asp?item=N82E16817341008
Western Digital Raptor X WD1500AHFDRTL 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive
http://www.newegg.com/product/product.asp?item=N82E16822136035
Western Digital Caviar SE16 WD7500KSRTL 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - Retail
http://www.newegg.com/product/product.asp?item=N82E16822136222
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink - Retail
http://www.newegg.com/product/product.asp?item=N82E16835118003
SAMSUNG Black 20X DVD+R 8X DVD+RW 16X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe - OEM
http://www.newegg.com/product/product.asp?item=N82E16827151154
Logitech G15 2-Tone 104 Normal Keys 29 Function Keys USB Wired Standard Gaming Keyboard - Retail
http://www.newegg.com/product/product.asp?item=N82E16823126034
RAZER Copperhead Tempest RZ01-00050100-R1M1 Blue 7 Buttons 1 x Wheel Gold plated USB Laser Engine 2000 dpi Gaming Mouse - Retail
http://www.newegg.com/product/product.asp?item=N82E16826153105
Ok I think I have everything. There are a few things I am concerned about that maybe some of you can help me with.
RAM - i see most people are getting 2x1gb sticks to get 2 gigs or 4x1gb sticks to get 4 gigs. i would like to do 2x2gb to get 4 so that leaves me room to upgrade. is there a reason people are getting 1 gig sticks and not 2 gig sticks? also i see a lot of ram is being incompatible with the motherboard i chose, so i was wondering if anyone could give me suggestions, i see the aproved vendor list doesnt have much, and i havnt seen anyone using 2x2gb sticks. I have checked the asus forum and have not got much help there.
my budget is a max of $2000 with this. i already have a decent 19" widescreen samsung lcd monitor, which i plan to upgrade in the next year. I plan to do a little overclocking. I think im gonna go with windows xp 32bit, then installing vista 64 on a separate drive later in the future, probably after service pack 1. everything else i need to purchase. I guess i just want to see what people think of my choices and hoping to here some constructive critisism as i have not built a computer in over 4 years.
Thanks in advance!
