Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > x800pro vs x1950pro agp?
Forum Graphic & Displays : Graphics Cards - x800pro vs x1950pro agp?
I was wondering if it's worth it to get an x800pro for 50 dollars (used) rather than a new x1950pro for around 175. As far as performance goes how much better is the x1950pro than x800pro?
Sponsored Links
What are your system specs, what games do you play or hope to play, and what resolution do you play at? The SM2.0 X800 pro is not supported in some games already. Also, if your system isn't up to it, the X1950 pro could be a waste. The HD2600XT AGP is an option too as it has been as low as $99 (newegg), and without fsaa often comes close to X1950 pro performance. With fsaa, the X1950 pro typically leaves it in the dust. In the most demanding new games neither would have the oomph to use fsaa unless you are running a low resolution.
Edit: what country are you in? If in the USA I'll pick some good AGP deals right now. But you need to answer the questions above about your system and games or it may just be bad advice.
Message quoted 1 times
Message edited by pauldh on 02-01-2008 at 09:40:05 PM
Reply to pauldh
about $125 worth :) more performance.
but if you want a cheap AGP card that can be potenitally unlocked to a full 16 PP X800(using some modifications ofc) then yea the X800PRO is a good deal.
But if you got the cash the 1950PRO hands down.
Reply to Xazax310
Built this durable system about 4-5 years ago for around 800 dollars:
3.2Ghz Prescott P4 HT
Asus Mobo
2x512mb DDR Kingston Ram PC3200 - Dual channel
160x2gig WD HDD Raid 0
Radeon AGP 9600xt AIW 128MB
350Watts PSU
I will use to play games...no FPS (first person shooter)
Reply to ragingazn628
Ah, weak link would be the PSU depending on the Quality, if you upgrade to a X1950PRO, you would need a 450+ PSU i recommend Cosair PSU:
$70 Cosair 450w
http://www.newegg.com/Product/Prod [...] air%2b450W
i cannot agree with PaulDh about the 2600XT its simply junk and underpowered the older gen cards stomp it in games and who wants to play without FSAA? the X1950PRO would be the better choice for performance.
Message edited by Xazax310 on 02-01-2008 at 11:02:45 PM
Reply to Xazax310
What is the SM2.0? I do live in the US. Right now I have WoW, Warcraft 3 , and Guitar Hero 3. Guitar Hero 3 is lagging a bit so that is why I am trying to get a cheap video card (AGP system). What AGP deals can you pick for me?
SM2.0 is simply the shader model used, your old 9600XT only supports 1.1 i believe, hence why in those newer games you might lag.
Those are good deals however i would shop around local stores as well as other E-Tailers and see what they sell
Reply to Xazax310
Asus Mobo
350Watts PSU
Looks familiar. LOL :lol:
Anyway, I'll agree with pauld about the HD 2600XT upgrade. PSU suggestions would be an Antec Earthwatts 430W
http://www.newegg.com/Product/Prod [...] 6817371006
it's a good quality, high efficiency unit with 30A on the 12V for $55 w/ free shipping. Can't really beat that on a budget.
Good luck finding an X1950 AGP, Newegg hasn't had them in a while, and a quick froogle search showed they're crawling north of the $300 mark (for the Pro version). That cost is NOT justifiable. Period.
------------------------------ Lian-Li PC-7B | XClio Greatpower 550W | P4 3.2 Prescott SL7E5 | Scythe Ninja
2GB DDR400 Corsair VS (4*512) | eVGA nVidia GF 7600GS AGP vmod 1.46/1.91 OCd 759/907
WD 160GB & 640GB SATA
WinXP MCE 2004
Reply to KyleSTL
Well the x800 pro I am trying to get is only 40 bucks... any opinion on that?
I believe your PSU would be pushed pretty hard with an X800. When I upgraded to the 7600GS, my PSU started giving out on me and I kept getting "Video card is not receiving sufficient power" messages. I'm fairly certain my PSU was succumbing to an decrease in its peak output due to capacitor aging and a newly elevated level of demand. My PSU was a Delta 365W OEM and the 7600GS and X800 have similar power requirements (27W and 37W, respectively from http://www.atomicmpc.com.au/forums [...] t=9354&p=0 ). So, with a 350W PSU, it looks like you'll be upgrading either way. I'd say go for the 2600XT still, even with the X800 at that pricepoint.
WinXP MCE 2004
Reply to KyleSTL
$70 Cosair 450w
Really, I'll give you some links to hot new games to look over so you can rethink that. In AGP you don't do much better than the HD2600XT. And for 75% more money the X1950 pro is a terrible buy compared to it. You'd rather have him put $175 into that? SHow me a new AGP card for $100 brand new that comes anywhere near the HD2600XT. And who plays without fsaa? ... People who play newer games at over 10x7 with a $100 or less AGP card, that's who. I'm an fsaa junkie myself, but let's face it we are talking AGP here. Throw in crysis, does fsaa matter with any AGP card? Anyway, just comes down to price/performance IMO. I've seen the HD2600XT in action, and in my eyes at $99 it's by far the best bang for buck solid AGP gaming card.
Crysis: http://www.legionhardware.com:80/d [...] id=698&p=2
UT3: http://www.anandtech.com:80/video/ [...] i=3128&p=4
HL2 ep2: http://www.anandtech.com/video/sho [...] i=3122&p=3
TF2: http://www.legionhardware.com/docu [...] id=691&p=2
Reply to pauldh
OP, those are good enough specs to justify almost any AGP card made IMO, but I highly recommend you look for getting alot of performance for your money. In some games you will be more cpu limited to some extent, and your X1950 pro price is pretty terrible. Combiine those two and I would avoid a $175 X1950 pro. But it depends on your pricing on other cards.
Also, an older 350W PSU is probably has a single weak 12v rail and will greatly limit what you can put in it. With the X1950 pro they recommend 30 amp 12v, although you could be fine with 26 amp I'd think depending how loaded the system is. Yours may be 14-16 amps only if it's an older 350W PSU, and factor in aging on top of that even. If that's the case, you won't go far upgrading while keeping it in the system.
edit: In the USA, here is the card I recommend. But again you will need a good 22 amp 12v or more IMO to confidently run it. Then use the latest Cat 8.1 hotfix drivers from ATI or Sapphires site with it.
http://www.newegg.com:80/Product/P [...] 6814102711
Message edited by pauldh on 02-02-2008 at 12:08:45 AM
Reply to pauldh
The X1950Pro will easily beat a x800pro.
If you care about performance, I think it's better to get new everything. Even a new low-end system will run much better or just save your money. Totally useless? Yes until you can't get replacement parts anymore. I was in the same boat 1 year ago.
Reply to enewmen
I can't speak for the AGP version, but I went from a X850XT Plantinum Edition to a X1950pro, and there is quite a difference. I would highly suggest thinking about the 1950pro if you are any kind of gamer, and you can swing the extra cash for it and a power supply. But then, if your cash is limited, the 2600
XT that has been mentioned is a good choice for the money.
Too bad you don't have a PCIe slot, I have that X850XT PE sitting in the closet, ran it only for about 3 months, it's in perfect condition and would make you a screaming deal on it.
However, both cards would need a good power supply to run them.
Reply to jitpublisher
but definitely x800 pro is better than the 9600xt right? I just plan on having this card for a little while and save up some cash and build a brand new system =) I mean a 40 dollars upgrade sounds alright.
X800 pro is way better than the 9600XT. Matter of fact it's way better than the 9800XT that ruled that generation.
Reply to pauldh
Quick review example:
http://www.neoseeker.com/Articles/ [...] iew/9.html
Message edited by pauldh on 02-02-2008 at 12:42:43 AM
Reply to pauldh
is the x2600xt WAY BETTER than the x800pro? is it worth the extra 50?
IMO yes. Not only way more powerful, it's supported in all games. The X800 pro is an SM2.0 card with no official support in SM3.0 only games like Bioshock, MOH:Airborne, etc.
Edit: Let me put it this way, the HD2600XT would very often do to the X800 pro (double it's performance) what the X800 pro does to your card. If I run upon any direct comparisons in my favs, I'll post it.
Message edited by pauldh on 02-02-2008 at 12:49:37 AM
Reply to pauldh
Although I'm looking forward to rebuilding soon - I've had an X800Pro for almost 4 years now.
I'm not sure about power supplies - I've always had a 550 watt.
But the x800pro has been good enough to play COD4 demo on medium settings and Crisis demo on medium settings for a good enough single player experience. (at 1280x1024)
I've always played the Novalogic Delta force games including Joint Operations/escalation etc and the card has worked fine.
Depends on your cash situation and how longer you can wait to save and what other bottlenecks could slow any upgrade component down etc. Good Luck.
In life - if it isn't a HUGE risk - maybe just go for it and see what happens! Follow your heart and be happy..
Reply to a_dude
hmm - will the x800 pro be good enough to handle Starcraft 2? ETA 1 year or more?
AFAIK, Starcraft 2 is rumored require only SM2.0 cards like the your 9600XT/9500 pro even. We will have to wait and see though.
The X800 pro is a good card, I have owned one and used many. Also owned a X800XL, and still own an AIW X800XT and X800XTpe. Those two have plenty of power for most current games, just get left out in sm3.0 only games.
Reply to pauldh
See I only play strategy games and MMOs - the only MMOs I play are WoW and Guild Wars (it's been months since I touched them due to college etc.) But I think I might be getting back to it. I play FPS games on xbox360 ps3 etc not computers but yeah I think the x800 pro is good enough until like the geforce 9 series come out or something then I will build a new system ... maybe =D
Unless a specific game you want to play doesn't support the X800 pro (requires sm3.0), it should be totally fine for you.
edit: BTW, what games that you play are hurting on the 9600XT? Something like C&C3 can be very demanding, but also can play on a radeon 8500. If I'm not mistaken, GuildWars is the same min R8500, rec R9500/9600.
Message edited by pauldh on 02-02-2008 at 01:30:46 AM
Reply to pauldh
=D thank you for your time now I hope to win that bid =)
your welcome...good luck. :)
Reply to pauldh
Listen to Paul, he knows whart he's saying (other than the R9600 is better than everything, of course that's based on Evilgoalie Logo not Rendering/Gaming power), but the HD2600XT and X800Pro should be fine, especially for the PSU involved.
PS, the R9600XT is PS2.0/DX9/SM2.0, the PS1.1 cards are back to the R7200 days, the R8500 was the first PS1.4/DX8.1 cards. The advantage of the X800 shader wise over the R9600 (other than power) is the minor tweaks in PS2.0B, with some minor tweaks in shader length, lopps, etc, and the addition of better HyperZ support.
Good luck, the X800P should last you to your next upgrade, thankfully you don't play the games that require SM3.0.
As a former R9600P owner who had it OC'ed 50+/50+ mhz above the XT I can say that the X800P should show you a nice boost.
Message edited by TheGreatGrapeApe on 02-02-2008 at 01:54:35 AM
------------------------------ You need a license to buy a gun, but they'll sell anyone a stamp (or internet account) - RED GREEN. GA to SK
HD Freedom: 45 5F E1 04 22 CA 29 C4 93 3F 95 05 2B 79 2A B2
Reply to TheGreatGrapeApe
I Actually upgraded form an X800 xt to a 1950 pro cause I was getting really angry at the fact that alot of the new games I was getting were SM3.0 only. Performance is of course better, but not as much as one might think. The X800 still did pretty good. Also the 1950 pro is different than the big brother X1900's in the fact that it uses less power. It should be fairly comparable to the X800 in that regard. And my X800 oc'd pretty darn well too.
Reply to inglburt
^^ I am not an overclocker but this agp x800 pro I am bidding on has an artic custom cooling so I think I might over clock it? O.o btw Inglburt what did you do with your x800 xt?
turns out I lost the bid...BUT! there is a lower bid for 25 dollars ^^ ends in 12 hours... anyways is there an nvidia video card equivalance of x800pro?
if you have the money for sure the x1950 my friend has it it runs great he can play almost anything!
------------------------------ Asus M2N-E mobo, 4 gb ddr2 800 mhz ram, Amd Athlon 64 X2 4600+, Western Digital 500 gb hard drive, Thermaltake 700 watt psu, EVGA 8800gt
Reply to db4s
My first PCIE card was the x850xtpe, I later switched to the x1950Pro and can honestly say it was not worth it at all. If you can get the pro cheap, then it would be worth it.
AGP cards are way to expensive for my blood, but I see the x1950Pro AGP and x800 AGP and 7600GT AGP all going for roughly the same price on ebay.
Message edited by TSIMonster on 02-02-2008 at 06:55:29 PM
------------------------------ The Truth About GPU Power Consumption
Home: E4600@3.6Ghz|AC7|P35|4GB|640GB|8800GT|Vista64|24" P-MVA
Work: Phenom9500@2.5Ghz|AC64|690G|3GB|500GB|8600GT|XP|2x22" TN
Reply to TSIMonster
results:
ended up winning an auction at 56 dollars no tax no shipping =)
went from 4009 on 3Dmark 03 to 10k over 2.5 times the score! any thoughts?
Hey good deal. My thoughts would be to move away from 3dmarks and play some games with higher res/ detail/eye candy. Enjoy that new card.
Reply to pauldh
There are 1212 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
