Hello all, this will be my first build, and I'm new to the forums here as well. I'm open to any suggestions for change... Mostly will be for playing games and some database crunching stuff. Was going to go with the Q6600, but then the e8400 came out and just seems to make more sense...however, unless I can find a motherboard that I am 100 percent sure will post so I can update it via a flash drive or find a motherboard that already ships with a BIOS that works out of the box, I may just spend the extra cash to get a Q6600 and not worry about it. Also, the power supply may be overkill, but...I dunno, just seems like a nice one and might be useful in the future and has a very good combo deal with my first motherboard choice from newegg.
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black PATA Model SH-S202N - OEM
LIAN LI PC-61 USB Black Aluminum ATX Mid Tower Computer Case
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
Rosewill RC-403 Conexant 56Kbps PCI Bus (Plug & Play) Modem - WINDOWS VISTA READY!!!
EVGA 512-P3-N801-AR GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Arctic Silver 5 Thermal Compound - OEM
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400
OR the Q6600...
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD
ZALMAN 9500A 92mm 2 Ball CPU Cooler - Retail
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard
OR
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard
OR some other motherboard for the e8400...
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply
OR the Q6600...
OR
