Help choosing 4GB of Memory - 2x2GB or 4x1GB
Last response: in Memory
This is going to be my new set up but I was wondering if anyone could had any suggestions on the best memory I could get for about $125 or less. I would like 4GB total so two 2GB sticks or four 1GB sticks would be fine. I will most likely be overclocking it so any suggestions would be appreciated. Thanks!
Thermaltake ArmorPlus(Armor+) VH6000BWS Black Aluminum / Steel ATX Full Tower
EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard
SLI - 2x BFG Tech BFGE88512GTSE GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16
PC Power & Cooling S75QB EPS12V 750W Power Supply
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400
ASUS V-60 92mm Vapo Bearing CPU Cooler
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM SATA 1.5Gb/s Hard Drive
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
LITE-ON 52X CD Burner Black ATAPI/E-IDE Model DH-52R2P-08
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B
HT OMEGA STRIKER 7.1 Channels PCI Interface Sound Card
Microsoft Windows Vista 64-Bit Home Premium
More about : choosing 4gb memory 2x2gb 4x1gb
Related ressources
- WTF??? 4x1GB or 2x2GB !! plz advise - Forum
- whats better 4x1gb ramm or 2x2gb ramm - Forum
- 2x2gb vs 4x1gb - Forum
- 4X1GB or 2X2GB vitesta decision... - Forum
- 2x2GB or 4x1GB - Forum
I have the same motherboard and processor as you.
This is the memory that I have. There's a mail in rebate for it too, which is nice. I haven't had any problems with Corsair memory, but I also haven't overclocked anything yet either.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145176
There are so many manufacturers out there, you can search forever. I heard some people have issues with the OCZ memory with the 780i board, but then again there are others who don't seem to have any problems with them. Maybe check out the EVGA forums.
Ya, I thought about picking up that Corsair memory.
I was also looking at this Crucial too http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Has anyone used this crucial before?
The stuff OCs well past 1066mhz in pretty much every review, it wont do you wrong.
CRH that is like nearly the exact system I'm settling on building...although I'm kind of taking my time waiting to see what the 9800 higher-end stuff looks like.
Off topic question: How did you decide on that power supply? And will that fit in the ThermalTake Armor with it's funky side mounting power supply? And why are you confident that will be enough juice for that system with a little breathing room for possible GPU upgrades?
Ya, I was thinking on waiting to check out the 9800 series cards since the 9600gt did so well. I might weight but my patience is getting low cause I've been waiting for a while to build this. I am confident in that power supply. I've done a lot of research and that seems to be one of the best out there. It supposedly rated lower than the power it can actually put out. I think it will be just fine for years to come. I don't see it having any problems fitting in that case. It goes in the top slot horizontally just like a lot of other cases.
I'm not sure about the ArmorPlus, but with the Thermaltake Armor the PSU mounts sideways at the top. The know the badass Galaxy won't fit, but that sucker is too expensive and 1kW is a hell of a lot of power LOL. Just something you may want to double check.
The only downside I see to that power supply is that the cable is not modular...according to the quick research I did (AKA looked at pictures LOL). That's not really an issue though.
CRH how much does that cost? You are really helping me out...the basically 2 things I was unsure about were the PSU and RAM...I have to re-read this thread and see if that Crucial isn't too expensive. I will probably do some OCing as well, although likely not any extreme OCing (running air and not experienced with system OCing but am experienced with graphic card OCing).
ddr2-800 is so cheap at the moment you can get 8gb (4x2gb). the big question is will the memory controller pull from 4 sticks at once or just pull from 2 sticks and piggyback the other 2 sticks? from what i understand is on intel boards it just pull channels a1 and b1 and piggyback channels a2 and b2. but, amd pulls from all 4 channels at once. as you can tell, if memory bandwidth is what you need then obviously 4 sticks on an amd board is the way to go. if your doing encoding then intel is what you want because the processor can't process as fast as the memory fed to it. to make a longer story short, 2x2gb on intel boards, 4x1gb on amd boards. but personally, id do 4x2gb on amd board. all this is with the assumption your using vista 64-bit.
Below is my 2 cents and what I wrote on newegg. I dont know if anyone still cares, but I like this ram. It is serving me well so far.
Pros: Over-clocks. Stock DDR2 800 ram (like this is) runs at 400 MHz. I have mine at 510MHz. It might go further, but my CPU is maxed so I can't tell. I have my settings at 5-5-5-18 and 510MHz. Wow!
Cons: If your not smart and push on the heatsink, you can break them off.
Other Thoughts: Get this ram. Your overclock might vary from mine. Overclocks are never straight accross the board.
Waspy, the Crucial is cheap. $110 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I'm only gonna go with 4GB right now. I don't think anymore than that is really necessary right now. I can always buy another 2 sticks later on if I feel like it and pop them in.
you really should reconsider 4x2gb instead of 4x1gb. with vista 64-bit you can place an entire dvd rip in memory and encoded much faster than with just 4x1gb sticks. what i mean is with you will have at least 2 hdd accesses (actually you'll have 3 because your using 32-bit vista and 32-bit vista can't see more than 3gb of memory). witn vista 64-bit and 8gb of memory you'd be able to transcode a movie in about a 1/3 less time than if your constantly accessing the hard drive. you be able to transcode a 120 minute movie with nero recode in about 37 minutes on vista 64-bit and a q6600 processor. absolutely outstanding. just think of the possiblities...backing up 10 year collection of 4,000 dvd movies in less than three weeks, when before it took nearly 3 months. go 64-bit vista, any quadcore processor, 8gb of memory and never look back.
hairycat101 said:
Dang it! This advice was not intended for you! Pay no attention to what was said here. Go buy a Dell.
just kidding. What is your ram clocked at? 916 GHz!?!?!? Really?You know whats funny, before I read your reply, I had changed my signature/specs as I realized that I had it wrong. Then 916 was when i had my cpu at 3.2...... I recently went to 3.3 cuase I have a friend just buy a 3.2GHz cpu so I just had to beat him.... Silly, I know
I know I can get 3.6 out of it, but thats almost a 100% OC and it feels wrong in my soul...... dont know why.....
I think I might have changed my mind. This memory seems really nice and runs at 4-4-4-12 at 2.1V.
http://www.newegg.com/product/product.aspx?item=N82E168...
xringx said:
You know whats funny, before I read your reply, I had changed my signature/specs as I realized that I had it wrong. Then 916 was when i had my cpu at 3.2...... I recently went to 3.3 cuase I have a friend just buy a 3.2GHz cpu so I just had to beat him.... Silly, I knowI know I can get 3.6 out of it, but thats almost a 100% OC and it feels wrong in my soul...... dont know why.....
still don't think that giga-hertz is the correct measure
Jpain said:
http://www.gskill.com/en/f2-6400cl4d-4gbpk.html4GB Dual Kit DDR2-800 F2-6400CL4D-4GBPK 4-4-4-12
I tend to go with the G.Skill over the OCZ.
The OCZ has issues with some MB's,voltage issues,the tall HS may forbid it's use with some coolers and it tends to sale for more.
Another good ram is Patriot which also imports and sales the chips for other companies to use for their own sticks.
Shadow703793 said:
Ah... but the Crucial Ballastix are guaranteed to have D9 chips.Fair enough. I am getting 510 MHz out of mine... DDR2 800 is supposed to run 400 MHz. I'm gettin a good OC out of mine. OCing is not gaurateed to be the same across the board though. What kind of chips do I have in mine? Any one know?
Related ressources:
- Forum4GB 2x2GB doesn't work with 2GB 2x1GB kit well ?
- ForumDDR2 4GB KITS ( 4x1GB ) vs ( 2x2GB ) Which is faster?
- Forum4GB : 4x1gb or 2x2gb
- Forum4x1gb or 2x2gb with Gigabyte mobo
- Forum4x1Gb or 2x2Gb PC2-6400
- Forum4x1Gb vs 2x2Gb PC6400
- Forum4x1GB or 2x2GB ?
- Forum2x2gb or 4x1gb ?
- ForumHelp with 4GB of Memory
- Forum8gb DDR2-800 vs. 4gb DDR2-1066 ?
- Forum4x1gb or 2x2gb need opinions or facts
- ForumDDR2 RAM: Better performance with 5GB @ 800MHz or 4GB @ 1066MHz?
- ForumIntel i5 3550p & AS Rock Z77 PRO 3
- Forum.inf files! help me someome please!
- ForumHelp me sepend my money
- More resources
Read discussions in other Memory categories
![[:thegreatgrapeape:6] [:thegreatgrapeape:6]](http://m.bestofmedia.com/sfp/images/design/usr/smilies/cc/68/thegreatgrapeape:6.gif)
