I am looking for a case that can easily hold 8 plus hard drives and have ample airflow through them. The only case I have found that comes close to meeting my needs is this Lian li case but it is rather expensive.
I am also looking for a power supply that has a enough connectors for at least 8 sata power plugs and 6 molex connectors for ide drives and fans. I have a 500w Antec modular power supply now that seems to do fine on the power side of things but it is lacking in connectors.
Any help you can provide would be much appreciated.
CoolerMaster Stacker TO-1 holds two PSU's and 11 HD's/ROM's/Front Panel controlers.
It also can mount mini-ATX,ATX or full sized server MB's.
It is also still the best cooling case around.
Remove (unscrew) the rear exit fan grill for 100% unobstructed airflow.
The whole front has airflow as well as a 12" round side (with filters) and the other side has a 12 1/2" X 3" vent...the bottom of the case is about 40% vented as well.
They offer an optonal Crossflow fan that draws air from the 12.5"X3" side vent and moves a 34qfpm wave of air accross the MB (top-to-bottom) and all parts which is dirrected towards the exit fan.
PC Power & Cooling is the PSU I would use.
They are -constant- power draw rated with an intake air temp of either 40C or 50C for the Turbo line.
A model 610 for example has a -constant- rated 49Amps @ 12V on a single rail...so it's 100% useable.
They are $119 dirrect from the company.
You might order the dual PSU connector and use the PC P&C to feed your MB/GFX and first few drives while it powers up you other PSU to drive fans/extra drives.
Two 610's in this case give you 98Amps @ 12V -constant rated- for about $220 USD or half the price of thier KW units.
Look in my profile for my LAN system specs.
With a 50% OC on air the 7 systems run 2C over room temps.
Message edited by ZOldDude on 02-13-2008 at 03:47:36 AM
*While we crash and burn, small, low tech, agrarian societies such as the Hmong in the mountains of Laos will continue on without so much as blinking an eye.*
