Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need help reviewing components for possible issues
Forum Homebuilt Systems : New System Build - Need help reviewing components for possible issues
Ok, I think I have all the components for my new comp. I am hoping that if you look it over and see any possible issues with it, that you will let me know. Trying to avoid any problem. I will be overclocking. Money is not a big issue. Computer is primarily for gaming. I plan on using eVGA's step up program to buy 2 9800's when they come out.Thanks for any input.
Western Digital Raptor 150GB 3.5" Serial ATA150 Hard Drive $169.99
Seagate Barracuda 7200.11 500GB 3.5" SATA 3.0Gb/s Hard Drive 119.99
Creative Sound Blaster X-Fi Platinum Fatal1ty Champion Series Sound Card $169.99
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory $114.99
EVGA GeForce 8800GT Superclocked 512-P3-N802-AR Video Card $259.99
Intel Core 2 Quad Q6600 2.4GHz LGA 775 Processor $255.00
EVGA 132-CK-NF78-A1 ATX Intel Motherboard $259.99
ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T $38.99
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD $111.49
* Antec TruePower Quattro TPQ-1000 1000W Power Supply
* Antec P182 Gun Metal Black Computer Case
-$70.00 Instant
-$80.00 Combo
$50.00 Mail-in Rebate
$469.98
$319.98
Thermalright Ultima-90 CPU Cooler $47
92mm fan $15
UltraSharp 2707WFP 27-inch Widescreen Flat Panel LCD Monitor with Height Adjustable Stand $1100
Sponsored Links
Drop Q6600, and get Q9300 for $266.00. This is the replacement of the Q6600, and overclocks much better at lower temperature. If you are not going to do any massive video encoding, you might want to go with a E8400 for $215 and then upgrade to Intel Nahalem by the end of the year . E8400 are faster than a Q6600 in gaming. According to bit-tech.net Benq FP241W lcd is the best gaming lcd at 1920x for at a price of $720, and beats UltraSharp 2707WFP in all the testings.
Message edited by rickpcnerd on 01-27-2008 at 12:55:21 PM
Reply to rickpcnerd
Quote :
Funnier if it came from a politician.
Drop Q9300, and get Nehalem. lol. Neither of which is out yet.
I do agree with E8400 for mainly gaming. It rocks. But swap that U90 out for a TR U120E + a Scythe 60cfm+ 12cm fan if money is not a big issue.
Reply to akhilles
There are 1421 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
