Tom's Hardware > Forum > CPU & Components > CPUs > cpu OC help, bad components??
Forum CPU & Components : CPUs - cpu OC help, bad components??
i want to overclock my cpu, which is e4400 with i945G/GZ , 82801GB ASUS board 3GB ddr2 pc2 5300, (2 brands)
bios is by Pheonix tech v.5.18
im not sure this mobo supports cpu oc, im nooooob to oc please help,
e4400 1.213V 2.00Ghz 10 X 200 bus speed. rated FSB 800mhz 2mb shared L2
mobo ASUSTek computer INC (model - leonite2) i945G/GZ (south - 82801GB)
bios PHoenix Technologies, LTD 5.18Ver
RAM DDR2 3GB 333.4Mhz, ration 3:5 5-5-5-15-21 (pc2-5300)
Brand 1 - hyundai electronics, 1GB 333mhz 5-5-5-15-20 X2
Brand 2 - Corsair, 512MB 333mhz 5-5-5-15-18 X2
both 1.8 volt
sorry that i couldnt upload my screenshots of cpu z
but here is all m info about mobo, mem, cpu, my bios sucks, dont have many functions. is it possible to overclock??
please please help[
------------------------------ E4400, 3GB DDR2 PC2 5300, 2X 320GB HDD, 3X DVD RAM DL,
Radeon HD 2600Pro ICEQ Turbo, OCed (783/575) from (600/500) factory OC (650/525)
Corsair VX 450
GA-P35-DS3L
Sponsored Links
not the typical components use to oc, but it is never hurt to try, one thing is good is your cpu since it is 10 Multi, if you can set memory to 266 which is 1:1 native, you get 2.66GHZ.
and please get all information before you try.
Over clock forum has some post will give your some idea.
Reply to bob8701
- 0 +
The 945 is really not an overclocking chip set. Its main use is for stock speed systems with integrated video. I have not seen the ASUS board, but Gigabyte and others do not support overclocking with this chip.
The E4400 with at least a P31 chipset would be your best bet. A P35 chipset would be even better.
In either case, I doubt you will be able to go beyond the 266 FSB of your ram. If the BIOS allows, set the CPU FSB to 266 and see what happens. If the machine does not boot, simply reset the CMOS and all should be back to normal.
------------------------------ I know what I know, and I don't know what I don't know.
Reply to tlmck
my bios dont even have that function, i looked at it, got nothing.. is there a way to change bios,
Corsair VX 450
GA-P35-DS3L
Reply to jhyukkang
Bios is limited by the mobo and written for a series of mobos. You can't put a monster bios designed for a OC tweakers mobo into a low end mobo. You got a very basic mobo. Replace it or live with it.
If your gonna replace the mobo, you'll need different ram since your running two different brands if you want to OC well.. And you have a aftermarket CPU heatsink? And thought about new NB and SB heatsinks? You will generate a lotta heat, many standard heatsinks can't keep the temp down. And does your case have enough cooling? What about your PSU? Is the PSU a tier 2? What about video? What card you running?
Standard OC questions............
Message edited by Conumdrum on 02-15-2008 at 04:32:55 AM
Reply to Conumdrum
- 0 +
I have overclocked quite a few 945 boards. The FSB limit with the 945 is usually much lower than a 965 or P35, but with his chip he should be able to hit 2.6ghz. The problem here is that he didn't give the right MB model.... This is an HP machine? With a crippled BIOS! It is actually a P5LP-LE. Still this MB will overclock with a BIOS upgrade. It needs to be flashed with the latest P5LD2 BIOS. *At his own risk of course*
------------------------------ Biostar Tforce P965,E6400@3.7ghz,Titan A04 cooling w/2nd radiator,3gb Crucial PC2 8500,8800GT 512mb,RaptorX C drive,RaptorX game drive,Dual Samsung 500gb Spinpoints,Hiper 880 PSU,dual Pioneer 20x DVDs,Hanns G 28" monitor,Sound Blaster X-Fi,Logitech THX Z-
Reply to vtr99
There are 648 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
