Lots of people with problems mounting and aligning this cooler. From what I have found, there is a pretty simple way to get the performance that the cooler is known for!
First off! The push pins. The faster you get rid of them, the faster your Xiggy will work!
I personally used 4 screws with matching tiny bolts, and just bolted the cooler on. Works great! No need to second guess the push pins, which I have NEVER gotten to work!
Next up.. your cooler. The Xiggy can only go on one direction and function to maximum potential. (That I have found!)
So first up, how to apply paste!
Three thin lines down each heat pipe where it will be contacting the IHS of the processor. (Integrated heat spreader.)
Next up, you look at the IHS of your processor, locate the aligning notches, and make sure you know the direction your cores go! Once you know this, simply mount the xiggy where the middle heat pipe goes down this line on the following pic. (The Pic Is Not Instructions on how to apply paste! You will ONLY be placing thermal paste on the three heat pipes, none on the CPU!)
Good luck! Now maybe you will get the temps that I do, hehehe! (Wish i seen this before I placed my own xiggy on, would have saved me several hours too!!)
--Lupi
--Lupi
