Tom's Hardware Forums » Motherboards & Memory » Epox » 8RDA3+PRO SPDIF problem
Add a reply
 Word :   Username :
Bottom
Author
 Thread : 8RDA3+PRO SPDIF problem
Profile: stranger
More Information
Does anyone know what the deal is with getting a 5.1 channel signal out thru my SPDIF optical interface??? All I manage to get is 2 channel stereo. This board is capable of outputting up to 8-channel audio, or so say the specs.
I 've tried to configure my SPDIF in the Realtek Sound Manager. The problem is that I get a different tab under SPDIF than the manual... i.e. i have NO "SPDIF-OUT" selections, ONLY SPDIF-IN!
Yes, I have my speaker config set to 6-channel (durrr).
I checked all jumper settings to make sure I din't need to reconfigure them to enable SPDIF-OUT.
I also tried the coaxial digital (orange RCA) audio output. I got NO sound using this method... not even stereo.
Right now i don't think too much of the "auto jack sensing" capability of this board.... doesn't seem to work worth a darn for the digital audio section...  :fou:
FROM THE MANUAL:
8ch
Delivers 8 channel audio to bring you the latest in audio realism from DVD movies and games. Perfect for your home theater system.
quickSPDIF
On board SPDIF-out connector for quick connection to multi-channel speakers. Not only removes cable cluttering but also delivers loss-free digital audio to let you enjoy DVD movies and games with crystal clear sound.
btw: 8RDA3+PRO uses ALC850 w/AC '97 codec.
Nforce2 Ultra 400 northbridge and Gigabit MCP southbridge
edit to fix board model
Message edited by Mr Boogedy on 03-11-2008 at 06:19:00 PM
Related Pr oduct
Profile: stranger
More Information
Well I've found some info about this elsewhere... here's the link ICYI:
http://www.hardwareanalysis.com/content/topic/68775/
Don't know if that's the case but if the SPDIF TOSLINK and Digital Coax are only good for pass-thru of pre-encoded signals then that's just bogus and queer imo.
I guess i need to go out and buy a receiver that has discrete analog inputs in order to use this board the way I intend. grrrrrrrr...........
Just inlude a chip to mix the channels for a digital stream!!1 (I guess the old MCP-T did this, yes???).
Profile: member
More Information
see my reply in the sound card section
GA-X38-DS4 (BIOS F3)||E8400 C2D (3.6GHz)||2*1Gb Crucial Ballistix DDR2-800 4-4-4-12||320Gb WD Caviar||Cooler Master Real Power Pro 750W||8800GT 512Mb||HT Omega Striker 7.1
Profile: stranger
More Information
gotcha. Thanks jay
Add a reply
Google Ads
Relatives contents
