Tom's Hardware > Forum > Overclocking > General Discussions > Overclock help. Q6600 DFI lanparty DK
Forum Overclocking : General Discussions - Overclock help. Q6600 DFI lanparty DK
Hi, Im working at overclocking to 3.2 and I have been adjusting my cpu vid special. http://www.overclock.net/attachmen [...] 1203298992
this is the only voltage setting that I have been trying to adjust and each time i go up some the prime95 goes longer, last attempt was almost 6hours before it crashed. My max temp was 48C so im not too concerned with upping the volts a bit more.
Big question is. Am I adjusting the right voltage setting? Should I be changing more settings? my dram is set at 333/800 but i notice that when i launch the dram is like 850. I am prime95 testing right now at +50. and according to my cpu id during the test my core voltage is 1.312
thanks for the help
Sponsored Links
How odd, is that just what your board calls the voltage control for the CPU? I dislike it very much when they decide its time to re name something.
if it's just VCore, then you can crank it up a decent amount, and like you said, the heat is fine, so no worries.
You wanna pass at least 8 hours of small ffts, and 8 hours of blend.
As far as your memory speed goes, it depends on the memory divider you are using. Since you didnt mention the memory type and speed, its tough to tell! But most people run the memory in sync with the FSB, like you should!
And then, how about taking a peek at your processors VID with core temp, or real temp? That will tell you your starting voltage, so you will know just how much you are over it, or whatever. VID is good!
Once you know the VID, you can see just how much voltage you'll need!
--Lupi
Reply to Lupiron
heres a post that talks about my board and bios features.
http://www.overclock.net/intel-mot [...] losed.html
i dont understand what each feature does. Can anyone indicate to me the primary setting to change voltage for a overclock.
Reply to LB_Specter
- 0 +
LB_Specter's specs
Quote :
Antec 1200
DFI http://en.wikipedia.org/wiki/DFI Lanparty DK P35-T2RS
Q6600 GO stepping @3.0
Zalman http://en.wikipedia.org/wiki/Zalman 9700
2GB Mushkin blue
2GB OCZ http://en.wikipedia.org/wiki/OCZ_Technology camo
EVGA 8800gts
2XSeagate 160gb RAID0
What is each RAM rated, DDR667/800/1066? What is the voltage spec of each.
Reply to Zorg
My ram is DDR2(800)
I just had a successfull overclock to 3.2 here is my results....
Im posting new results for 3.2GHZ. it took some doing but I finally primed for about 14hours with max temps of only 51C.
http://valid.x86-secret.com/show_oc.php?id=402018
Freq : 3197.69 MHz (355.3 * 9)
Core Voltage: 1.344 **Overclocked the CPU vid special add to +50.0mV http://www.overclock.net/attachmen [...] 1203298992
Motherboard: DFI Lanparty DK P35-T2RS
Case: Antec 1200
Cooler: Zalman 9700
Maxtemp: prime95 14hours 51C
Reply to LB_Specter
- 0 +
What's your RAM 710.6 (1:1)?
It doesn't really make that much difference, but if you're bored why don't you try:
CPU 400 x 8 = 3200
RAM 400 x 2 = 800 (1:1)
Unless of course, you are planning on going higher, then just raise the FSB.
I've got mine set to 3.2/800 and Vcore on auto. Idle CPUZ of 1.152V (C1E enabled) and Prime95 of 1.264V.
Message edited by Zorg on 08-12-2008 at 01:19:26 PM
Reply to Zorg
- 0 +
What are you measuring core temps with, Real Temp?
Are you running small FFTs?
Message edited by Zorg on 08-12-2008 at 01:30:06 PM
Reply to Zorg
yes, i used realtemp and im doing large fft for maximum heat.
Reply to LB_Specter
- 0 +
Small FFTs create maximum load and heat on the CPU. Run it again with small FFTs and your temps will be higher.
Reply to Zorg
I appreciate your help. I wish we had the same bios because there are way too many settings in mine. I will try it. thanks.
Reply to LB_Specter
- 0 +
Wonder if he will ever look to see what his stock voltage is, before playing around with it, hehehe!
--Lupi
Reply to Lupiron
There are 1235 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
