Power Supply - Something Wrong ?
Well I have just built this new computer.
This is what I have put together.
Motherboard: MSI K9N4 - Chipset: NVIDIA nForce 500 SLI
CPU: Socket AM2 AMD Athlon 64 X2 5200+ 2.6ghz Dual Core
RAM: OCZ Gold 2GB (2x1GB) dual channel 800 MHZ DDR2 - CL 5-5-5-12
GPU: Nvidia GeForce 7600GT
HDD: 1 Internal 80gb Seagate (IDE) - 1 External 320gb Seagate (USB)
CD/DVD: 1 HP DVD/CD Writer
PSU: Codegen Switching Power Supply: 375W
Once i boot my pc up I have a program called PC Alert 4 that shows temperatures, voltages, and fan speeds etc.
Everything looks fine for about the first 30 seconds when it loads. This is how it looks at first.
Then after about the 30 seconds it turns into this.
Is there a problem with the psu or am I just missing something?
Thanks
27 answers Last reply
More about power supply wrong
  1. Don't think you have a PS problem, just a problem with that software. I gave it a shot once and promply shot it. Check you voltages and temp in your BIOS and see if everything is ok there.
  2. I agree on the bios thing, you should check them there...
    besides, its not the first time programs show WRONG sensor data.
  3. KJThaDon I agree with tamalero & cardio check bios,I used gigabyte temp sofware once.its crap,you could download speed fan,its alote better temp software and it free.
  4. Thanks for your quick replies guys. I did look into the bios at the temperatures. I am not sure what I am looking for, the PSU is my weakest knowledge of a pc. Here is what it shows in the bios.
    SYSFAN Speed: 0 RPM
    CPUFAN Speed: 3068 RPM
    MBFAN Speed: 7031 RPM
    CPU Vcore: 1.344 V
    +12.0V: 11.774 V
    +5.0V: 4.940 V
    +3.3V: 3.200 V
    Now do you think PC Alert 4 was just acting up or is there something wrong?
    If you need more info please let me know
    Thank you
  5. I have this same problem with PC Alert, is it your 12v coming up low? , sorry actually looked at the pic, yes it is your 12v, I had this same problem with 2 different PowerSupplies, still able to play Crysis and anything else; i was thinking it might be a motherboard problem, (reporting wrong levels) but now I think it's PC Alert. Is there any other programs out there besides Speed Fan?
  6. KJThaDon I don't know what you are trying to use this pc for games,music,etc but the ps would be the first thing I would look to upgradeing .yours.PSU: Codegen Switching Power Supply: 375W . the rest of your pc looks good.it's really a low end power supply.it's your choice.also make sure you cool your pc,good ventilation.hope this helps
  7. The best way to test +12v voltage is to hook a voltmeter into one of the molex connectors with the red lead on the meter to a yellow wire on the molex and the other lead on the meter to black wire. Simply stick each lead in the small plug and watch what it says, this is more accurate then any software or even the BIOS will get.
    Yeah I plan on upgrading the ps soon. It was the only major thing I moved over to this new pc. I figured it would be ok for now until I get a new one, I just don't want it to fail and cause problems to my board or anything else in the meantime. I use this pc for music / games and basically everything. Played crysis, Bioshock, and cod4 on here a lot recently and everything seems stable, hopefully that is the case.
    @ doormatderek good to know it's not just me, maybe it is a problem with PC Alert reporting wrong..
    I've taken a picture of my ps to show you guys the readings on it but I cant find the damn usb to grab the pictures, but once I do i'll post it.
    Since I do plan to continue on playing games on here, you guys would suggest getting a better psu right?
    If that's the case any suggestions? or what do I look for exactly on psu's? what would determine a decent psu.
    Thanks everyone
  9. KJThaDon first off tell every one that is posting on this thread how much you have to spend on this item.
    next take a visit to a place like newegg and read psu reviews on different ps.
    Remember that wattage alone is not sufficient. Be sure to evaluate brand, build quality, fans, rails, and warranty information when purchasing a power supply.
    do some home work, and then come back and ask witch psu you should go with,don't go cheap ,and you don't have to spend you life saveing on it either.also make sure you cool the beast ? case
    ask and they will be glad to help.
    major53 ps
    OCZ Technology GameXStream OCZ-700-GXSSLI 700-Watt Power Supply.it's in the game!!!!!!!!
    hope this helps you .I hear cod 4 calling me. there's killing to be done in this here town.lol
  10. Quote:
    Why are on earth would he want to read newegg reviews? I've seen people talk about how great the 8500GT is. If you want good reviews, ask smart people on this forum, or look at jonnyguru, hardocp, anandtech, etc for their PSU reviews. I don't believe any of the user reviews from newegg, they are to often written by those who have no clue about computers.
  11. OCZ 700W? Ok, I'm starting to believe that PSU overestimation thread from yesterday. That is absolutely overkill for a system like that. A Tier 1-2 with a good 12V rail rating at 450-550W is more than enough. Unless the OP intends to someday SLI/XFire 8800s or 3870s, that's not necessary.
    Seesh.
    Corsair VX450 or 520HX is more like it.
  12. KJThaDon see it's already paying off for you ,ask and they will come.
    ___________________________________________________________________________________________________
    Seesh.
    ____________________________________________________________________________________________________
    by the time this thread is over you will have your pick of good answers to your question.
    Sorry, I didn't read closely enough, here the information you need to determine Tiers and Rail ratings.
    Tiers -
    http://www.tomswiki.com/page/Tiered+PSU+Listings?t=anon
    http://www.xtremesystems.org/forums/showthread.php?t=108088
    Jonny Guru -
    http://www.jonnyguru.net/forums/showthread.php?t=1460
    Rail Ratings -
    http://forums.guru3d.com/showthread.php?t=205763
    David Hammocks Guide -
    http://forums.extremeoverclocking.com/showthread.php?t=136602
  14. Thanks for the links Kyle I will read up on those now.
    And yes I forgot to mention I do plan on SLI'ng In the future.
    Right now I'm looking to spend say $75 for a PSU. The cheaper the better of course, but not in place of performance and quality. Also a modular ps would be nice.
    Thanks all
  15. ALL the Corsair power supplies are a steal right now at buy.com. if you want modular look at the 520 or 620.
    http://www.buy.com/retail/searchparametric.asp?loc=62043&ra=zm01,p01,op01,nf01,em01&ze01=5185&em01=984
  16. Ok I have looked over a few in a few different places.
    Let me know what you guys think of these.
    Ultra / X-Finity / 600-Watt / ATX / Dual 80mm Fan / SATA-Ready / SLI Ready / Black / Power Supply
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1273341&CatId=1483
    OCZ / StealthXStream / 600-Watt / ATX / 120mm Fan / SATA-Ready / PCI-e Ready / Active PFC / Power Supply
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=1483
    Ultra / X-Connect V-Series ( XVS) / 600-Watt / ATX / 120mm Fan / 20/24-Pin / Modular Power Supply
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2143209&CatId=1483
    Ultra / X-Finity / 600-Watt / ATX / Dual 80mm Fan / SATA-Ready / SLI Ready / Titanium / Power Supply
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1273340&CatId=2036
    Ultra / X-Finity / 600-Watt / ATX / 135mm Fan / SATA-Ready / SLI-Ready / Black / APFC / Energy Efficient Power Supply
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2700095&CatId=2036
    Rosewill Stallion Series Dual Ball Bearing Fan RD600N-2DB-SL-BK ATX V2.2/SSI, EPS 12V 600W Active PFC Power Supply-SLI Ready, Auto Switching/90-264V UL, FCC - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182087
    COOLER MASTER eXtreme Power RP-600-PCAR ATX from factor 12V V2.01 600W Power Supply 115/ 230 V Safety Nemko, TUV, cUL, CE, BSMI, FCC, CCC - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817171013
    Thermaltake Purepower W0100RU ATX 12V 2.0 500W Power Supply 115/ 230 V UL, CUL, TUV, FCC, and CB certification - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817153052
    CoolMax 600W SLI & Crossfire Certified ATX Power Supply - 14615
    http://www.buy.com/prod/coolmax-600w-sli-crossfire-certified-atx-power-supply/q/loc/101/202367539.html
    OCZ StealthXStream 600W Power Supply - OCZ600SXS
    http://www.buy.com/prod/ocz-stealthxstream-600w-power-supply/q/loc/101/204665531.html
    Corsair 520W SLI Certified Modular ATX Power Supply
    http://www.buy.com/prod/corsair-520w-sli-certified-modular-atx-power-supply/q/loc/101/203270716.html
  17. Corsair HX520 is probably the best of the bunch from what you listed. Ultras and Thermaltake are hit and miss, Rosewill is generally junk, along with CoolerMaster, CoolMax has nothing worth buying in the price range(they have a couple decent higher end PSUs). OCZ is fine, but not as high quality as the Corsairs are, OCZ uses FSP for their OEM, which can be both a good or bad thing, but Corsairs are made by either SeaSonic or CWT, this one is SeaSonic, which is a very respected PSU maker.
  18. I agree with Grave. Of those you listed, I would get the Corsair. The 520 is truly a great PSU. If any of those Ultras are a X3 series, I would run one of them if for some reason you don't like the Corsair. The X3 line is rather good. TT, "coolmax", "rosewill", etc are all junk. Its better to just avoid them. OCZ's are good, but from what I see when I read reviews their quality is starting to dip a bit. They are still good, but the Corsair is better.
  19. Agree with everything above.
    You just missed a good deal from buy.com - the corsair 550W PSU was on sale for $68 (now it is $83, still a good deal).
    Have you considered the PC Power and Cooling Silencer 610W? It is quiet. It is tier 1 on those lists. It seems to be a favorite on this board as well. You missed a sale a while ago, it was $109. Now it is back up to $119. Still a good deal.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005
    Give it a day or two, I am not saying this will happen, but they did this a couple weeks ago too. The price went up for few days , then came backdown.
  21. I hope you are using peerguardian with your bearshare
  22. Ok well I'm going to also need a 160gb sata seagate Hd ordered with the psu I choose. I have about $130 total for both...
    I put these 2 packages together if you guys can help me out I'm kind of lost which one to choose.
    PACKAGE 1
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1273340&sku=ULT31847
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2937363&sku=TSD-160AS5
    PACKAGE 2
    http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=371926
    http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117007
    I Am thinking more towards package 2 but I am not quite sure.
    The PSU in package 2 is the cheapest I found that psu. You can see the other prices on other sites of PSU 2 nowhere near this deal.
    http://shopping.aol.com/extreme-power-rp650pcar-650w-power-supply/29033760
    These are the info on the psu's
    Package 1 PSU
    Package 2 PSU
  23. Last minute choice
  24. http://www.newegg.com/Product/Product.aspx?Item=N82E16817103940 (Antec NeoHE 500W)
    and this
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
    (160GB Western Digital Caviar SE)
    Would be much better choices then the above two combos listed. I have that same power supply, its got nice, sleeved modular cabling and good +12v power and efficiency. Tier 2 power supply also!
  25. I'd second the recommendation on the Antec, especially if you have an Antec case....and the model Grave listed has a $35 rebate which puts the cost under $50.
    IIRC the 550 and 650 models are newer and have the quieter fans but the 550 has no rebate and costs $89. The 650 is $89 after a $40 rebate. That would future proof you a bit.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371001
    I'd take the Seagate 7200.10 160 GB over grave's choice tho. You are gonna pay $3 more than the WD model but that gets you a 5 year warranty
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148230
    Better yet, if you getting that 500W Antec for $50, you can opt for the Seagate 250 GB for $70 could stay $10 under ya $130 budget while doubling cache size and still getting that 5 year warranty,
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
    Finally, with the 500 W Antec, you can opt for the Seagate 3200 GB for $80 and meet ya $130 budget while doubling capacity, doubling cache size and again almost doubling the WD warranty
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148140
  26. I have the 320GB Seagate drive, its quite nice, currently my main drive with the 250GB Western Digital Caviar SE as the secondary. The Antec isn't very noisy, not audible over the other fans in my case, and it seems to have thermal throttling so it isn't always at max.
  27. For voltages it isn't uncommon to get a false reading with software, or even in the bios, some people have voltage meters and can find out directly if their rails are performing. I don't usually trust software, I put a little more faith into the bios but even then I don't fully trust it.
New Build Power Supplies Systems Product
