Power Supply Recomendation
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Power Supply Recomendation
Profile: journeyman
More Information
Hey - Quick question
Here's my system
6400X2
2gb 533mhz
8500GT
2 Ide HDs
1 Sata HD
1 DVD RW
Raidmax 500watt psu
What power supply would you all recomend for a single 8800GTS(G92)???
I don't plan on overclocking anything and other upgrades might be 800mhz ram or another drive and no sli
Thanks
Related Pr oduct
Profile: Ancient Poster
More Information
Your current PSU should be fine.
Not one I would recommend to buy, but you have it already......
Something as simple as the Corsair 450w would be a quality PSU that can easily handle the 8800GTS.
If its good in theory but not in practice,
its not good theory.
Profile: journeyman
More Information
thanks alot
What do you think of this one as well??
http://www.newegg.com/Product/Prod [...] 6817182032
Or is it overkill???
Profile: Honorary Poster
More Information
dbman19 make joke....  ha ha.
jonnyguru.com is your friend.
Profile: member
More Information
I recently went through the same process.  I previously used an Ultra PSU that I got free after rebate a while back, but finally listened to all of those comments about the importance of the PSU and that a substantial investment in other parts was riding on it.
The first step is to use a calculator like the one at http://www.extreme.outervision.com/  (there is a free Lite version or it costs just $1.99 for the pro version that gives you the amperage needed as well).  I ended up getting the Corsair 520HX from buy.com for $89 after a $10 rebate.  It got top marks from silentpc: http://www.silentpcreview.com/article699-page1.html and has a very high efficiency rating.  I can atest to the fact that it is extremely quiet and has modular cabling, which was a big plus.  The only negative thing I can say about it (and this is being extremely picky), is that the cables with sata connectors only have two connectors on each, meaning that for my three hard drives I had to run two cables to that part of my case.  From the manual, it appears that the 620w model has a cable with three connectors on it, which would have been more convenient.
Good Luck.
Intel BadAxe2; 8800GT 512mb
C2D 6600 w/ Arctic Freezer Pro 7
4 GB Corsair XMS2 PC800 / 4-4-4-12
1 x Raptor 150, 2 x Seagate 320 GB 7200.10
Profile: addict
More Information
Although every part WILL work (otherwise you wouldn't be able to sell anything), I wouldn't trust the cheap Rosewill's too much. You get what you pay for with PSU's.
Profile: Forum Veteran
More Information
dbman19 wrote :
thanks alot
That's a crap brand name. Actually, it's Newegg's own in-house "brand name".
Get the Corsair 450VX. It may "only" be a 450w PSU, but it can provide up to 396w (33 amps) on the 12v rails. That's just 24w (2 amps) less than that crap 600w Rosewill PSU. Plus the 450VX is made by a PSU manufacturer with one of the best track record for quality PSUs, Seasonic.
http://www.newegg.com/Product/Prod [...] 6817139003
Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | X1900XT 512MB | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi
There is no such thing as a stupid question.
But there are stupid people.
Profile: old hand
More Information
Or you could get the 450's big brother, great deal here;
http://www.buy.com/prod/Corsair-VX [...] 52646.html
Message edited by chuckm on 02-19-2008 at 11:04:55 AM
Opinions are like asses,everybody has one.
Profile: journeyman
More Information
Thanks alot
Add a reply
Google Ads
