Firstly Hello everyone!
Im looking to switch my current build over from air to water cooling. Got a stacker 832 case and at the moment im a bit unsure as to where I could mount the radiator, pump and resevoir. Wondered about putting the radiator in the 5 1/4" bays, or on the side panel, possibly even a single rad on the top with the top fan, but im really unsure if it'll fit.
Currently looking to cool a q6600 and 2 g80 8800 gts's, but would also consider the northbridge on the 680i mobo, as im after either a 4.2 or a 4.7 GHz clock on the processor, so any advice on components would be welcome, been looking at a lot of alphacool stuff as thats about all scan stock, but moneys not too much of a concern really, would rather have a quality loop than a bunch of cheap tacky bits.
Thanks!
Sam
Thanks!
Sam
