News
Tclink demonstrates car-radiator based cooling system
Published on June 05, 2006
If regular computer cooling system aren't just enough, Tclink/Ebiz offers a liquid cooling system that uses an "automotive" radiator. Read more
IBM promises cooler chips with capillary-action and water jets
Published on October 27, 2006
IBM's Zurich labs have developed a new heatsink and water-cooling that promises to cool chips up to six times better than conventional air cooling. The heatsink contains tiny channels similar to the capillaries you would see in tree leaves and in human circulator systems. The channels allow either water or heatsink compound to spread more uniformly and thereby dissipate more heat. Read more
Thermaltake Working On Affordable Compact Phase-change Cooling
Published on March 14, 2008
Hacienda Heights (CA) - During a recent visit to Thermaltake's office, we learned that the company is working on creating a compact phase-change cooling solution - which would be affordable for the majority of PC enthusiasts who are looking into extreme overclocking of their processors. Read more
CeBIT 2008: RAM Watercooling By Gigabyte
Published on March 05, 2008
Gigabyte, more commonly known for its motherboards and graphics cards, is presenting a water cooling solution for RAM modules, dubbed Cool Rain. Read more
Latest Reviews & Articles
Tom's Holiday Buyer's Guide 2008, Part 4
Published on December 02, 2008
Welcome to part four of our Holiday Gift Guide coverage. This time around, the Tom's Hardware staff picks its favorite components for your wish list rounding out 2008. Read more
4GB Gets Cheap: 9 Dual-Channel Kits Compared
Published on December 01, 2008
Recent price drops have made 4 GB DDR2 dual-channel kits affordable for even the most cost-conscious buyers. We pushed nine models to their limits to determine best value for a broad range of users. Read more
System Builder Marathon: Performance & Value
Published on November 28, 2008
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
System Builder Marathon: $1,250 Enthusiast PC
Published on November 27, 2008
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
  Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » water cooling q6600 at 3.0ghz and gtx 260 help
Word :   Username :
Bottom
Author
 Thread : water cooling q6600 at 3.0ghz and gtx 260 help
Fast, Reliable, Cheap. . . Choose two because you
Profile: stranger
More Information
I am getting ready to buy a h20 cooling setup for my rig. specs are as follows:
EVGA 780i MB
Q6600 will be @ 3.0Ghz (for now)
GTX 260 stock clocks
4 GB Hyper X mem 1066
Thermaltake Armor chassis
I will be watercooling the processor for sure, and eventually the GPU.
I am considering the Thermaltake Bigwater 780 AIO cooling system, and the Swiftech H220 Compact kit. I am leaning more towards the Bigwater because it just tucks in a few drive bays.
What other system should I look at?
I would like to avoid piecing it together myself as this is my first attempt at liquid cooling. Thanks
Comments concerns and ideas please.
Related Product
Profile: member
More Information
I woun't even speak to the quality as I've never seen nor used the Bigwater kits. What I can say is that I doubt very serioulsy a single fan radiator tucked into a drive bay could dissipate enough heat to make it much better (if at all) than a good and cheaper air solution.
I'm not a fan of the Swiftech compact kits unless you are space limited in your case - which the Armor is not.
The Swiftech H20-220 is a good introductory kit that you could build on. Also, Petra's Tech Shops has "kits" it's put together form individual parts if you're afraid you'll over look something.
http://www.petrastechshop.com/wacoki.html
I believe there are experienced Water coolers here who will gladly walk you thorugh the process, so don't feel you have to go it alone.
What is you budget?
Intel Q6700 Quad/D-Tek Fuzion V1 with 2xPA120.3/ASUS Maximus II Formula/PCP&C
Silencer 750/Corsair Dominator 4Gb PC28500 memory/Corsair Dominator Fan
VisionTek Radeon HD 4870/Swiftech MCW60-R/Raptor 150GB HDD 1 X WD Caviar SE16 500GB HDD/Mountain Mods
Profile: old hand
More Information
Bigwater kits are seriously flawed by their poor pumps. Their 'high flow 350 L/hr' pump doesn't perform nearly as well as the Liang/Swiftech branded MCP655 (1200 L/hr) plus you have a small radiator to cool a single CPU...nothing else and not even that CPU that well.
The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Profile: stranger
More Information
Not that the Q6600 needs watercooling at 3ghz anyway. I run my G0 at 3.1ghz with a Tuniq Tower and the fan set on lowest and the temp never hits 60 degrees C.
Profile: journeyman
More Information
the EVGA 780i mb has the potential to push q6600 above 3.6g, but anything above 3.2g, will be better off for H2O. You are on the right track.
Profile: old hand
More Information
Changing the FSB from 266 to 333 should be all there is to it from stock. It's when you start changing the voltages and pushing it higher that you really should consider a much better cooling solution than the stock HSF. Like some have said, air is fine, but its a person's own decision as to what is fine for them. :)
Profile: stranger
More Information
budget of around $400, and I hate to push a processor on air even though 3.0Ghz is very easy overclock for it. Thanks for the the ideas.
Profile: old hand
More Information
Please just don't come back and tell us you bought a Bigwater kit... :pfff:
Profile: stranger
More Information
Leaning towards the petra's coolkit elite. Looks like it is a very good kit, and leaves room for me to add a cooler to my vga eventually also.
Profile: stranger
More Information
My only suggestion is to disable automatic voltage on the cpu in bios cause the mobo tends to overvolt a little when OC'ed. I have mine vdrop/droop modded and keep the setting well below the automatic setting. Less voltage, less heat.
Google Ads
