Possibly but more details needed. Post your system specs and temps. Could be that CPU is overheating quickly and it is automatically shutting down for safety.
------------------------------DD Water Box Plus, QX9650 @ 3.9ghz, eVGA 780i, 4GB Corsair XMS2 DDR2 800(2x2gb), WD Raptor 150gb, 500gb Seagate Barracuda, BFG 8800GTX 620/2000 x 2 SLI, Tagan BZ 1300w PSU, Custom 120.2 Water Cooling
Reply to nzxtlexa
System is as follows:
MB: GIGABYTE GA-P35-DS3L LGA 775
CPU: Intel Core 2 Duo E4500 Allendale 2.2GHz LGA 775 65W Dual-Core Processor Model BX80557E4500
VC: XFX PVT84JUDD3 GeForce 8600GT XXX 256MB 128-bit GDDR3 PCI Express x16
HD: Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s
Mem: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
OS: Microsoft Windows Vista 32-Bit Home Premium
I don't think it is a heat related problem because it is reproducible from a cold start.
Disconnect the power switch from the mobo, and short the pins with a screwdriver. If the behavior stops, inspect the power switch and/or wiring; this behavior could indicate a short. Your PC shuts off just as though you'd held the switch for 4 seconds. If it doesn't it could be the PSU or mobo. Get a PSU tester and see what that says.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
That definitly looks like one of their lower end units. I'd suggest you check the UL code on the side and see who makes it. The gradual degradation sounds as if it could be power related.
------------------------------Official Corsair Tech Support. If You Need Help, Just Ask.
Reply to XMSYellowbeard
Thanks to all of you who tried to help. As it turns out, the case and components were manhandled by UPS which caused a number of plugs to come loose. All is well now that everything is attached.
Regards
Hah, I've even had UPS delivery throw a box of memory at me.
------------------------------3.8ghz Pentium D loading at 43C? What?
Reply to jbj190
