I'm building a new system, and I was just wondering if a Thermaltake ToughPower 850 watt power supply would be enough to eventually SLI two 8800 GTXs or, if my budget permits, a new series 9 card when they are released. (Side note: I know this will be enough for my system now, I'm just wondering if it would be enough with another GTX.)
Intel Core 2 Duo E6750 2.66 GHz
EVGA nVidia nForce 780i motherboard
Crucial Ballistix 2 GB (2 x 1GB) DDR2 SDRAM
2 x 250 GB Western Digital HDDs
Zalman 110mm CPU fan
nVidia 8800 GTX
2 x 120 mm case fans
Like I said, I'm sure 850 watts would be enough for this, but would it be enough for another GTX in the future, and possibly another hard drive and some more RAM? (Just wondering, Thermaltake's a pretty good brand, isn't it? Do you recommend any others?) Thanks a lot.
Yeah, that'll be more than enough.
I bought my CoolerMaster Real Power Pro 850W for the possibility of SLI'd GTXs and I run a lot more in my case than you do! Check my sig, that's what's running on my PSU!
PS peek at the CPU cooler charts on Toms home page Thermalright IFX-14Scythe SY1225SL12M won and the Zalman failed the test
PS PS...those WD hard drives are early 2005 vintage....DTR is half what current drives are.
Bad news. As it turns out, my budget might not allow an 850 watt power supply. Will a 700 or 750 watt power supply be enough to SLI two 8800 GTXs? They both have 4 12-volt rails, each with 18 amps on each rail. The GTX requires 28 amps so two cards will use 56, leaving 16 amps for everything else. Will this be enough?
The GTX doesn't require 26 amps (312 watts) , that's a system power recommendation, a 700 or 750 would be fine.
I've got a Thermaltake Toughpower 700wt and it does fine. The 700wt or 750wt will power two 8800s just fine with whyat you have listed. The 750wt model got high honors from jonnyguru, who marked it down only because it didn't look as nice as he would have liked. I could care less about its looks. I care about the performance.
Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
I'm not trying to push eBay, but you might find an 850 there at a good price. I sold a brand new Antec 850W TruePower Quattro there a couple of weeks ago. The high bidder got it for $122.75 + shipping.
The PC P&C is a good PSU, though as a personal preference, I like having a modular supply so that I only use the lines I need and not having a lot of unused lines cluttering up the case. That was the main reason I went with the TT Toughpower, along with it getting a high performance rating.
Some of the PSUs out there have really cheesy modular connectors, I prefer to just use what I need and and stuff the balance away. My case will never win the neatness award.
Message edited by Zorg on 02-23-2008 at 08:28:09 PM
I never cared much about neatness until I got a case that had a plastic side panel. Then I suddenly liked the looks of lighted stuff inside and and a clean interior, which led to the Thermaltake Toughpower. For my computer that has an old Chieftec Dragon case, a PC P&C works fine, as no one can see what lies underneath.
I've looked at the PC Power and Cooling PSUs and they look great, they get good reviews too, but the one thing I don't really like is the single rail. Aren't multiple rails better than just one?
That's really questionable. PC P&C puts out a good argument in favor of single rail PSUs, but since that's what they specialize in, their position is somewhat biased. A well built multiple rail PSU can be just as good, but it all depends on how it is designed and built.
The same thing applies to modular verses non-modular. It depends on the build quality. Basically, I'd suggest looking through the tier listings and to try not get less than a tier 2 rating. You can also check jonnyguru.com for specifics on various PSUs and their testing.
Come on Sailer, you know that everyone is moving that way, they just lie about it. All the Corsairs and Antec Earthwatts are single rail, and that's off the top of my head. I could get you a longer list if you want. The problem is that they lie and say that they are multi rail. Additionally, they aren't really even true multi rail. 99% are single rail with over current protection on the "rails", that isn't really a multi rail anyway. A true multi rail PSU has a voltage regulator per rail.
You're right Zorg, which is partly why I stated that the single verses multi-rail thing is questionable. Of the top lines of PSUs, its seems they are all going single rail, but they advertise themselves as multi-rail, particualrly the modular ones. The assumption, I guess, is that its less confusing to a customer if he reads that there is a given amount of wattage per line and he see different lines. So how to easily explain all this to the average person, and to then separate the single rail modular PSUs from the true multi-rail PSUs? With specs that keep changing as new stuff is made, I can't always keep up with the particulars. I find it easier to just tell people to look for a tier 2 or better PSU.
That said, the info from PC P&C's website will still be biased to the specific PSUs they make. It can't be expected that they would make their PSU one way and then say there was something better. An example is how they tell how bad 120mm and 140mm fans are, thus justifying their 80mm fan. Yet many of their competitors are using the larger fans sizes and telling how that with a larger fan, they can move more air when necessary and have a quieter fan. My own experience is that my Toughpower with a 140mm fan is so quiet I usually can't hear it at all, but the PC P&C fan has a whine that bothers my ears, and it gets worse as it heats up.
So I do stand by my statement of getting a tier 2 or better PSU and checking the reviews from jonnyguru for the particulars on given PSUs.
I agree with tier 2 or better, if you have the cash. Tier 3 will get you by, if you don't have the dough. The claims made by PC P&C, and all the others, have to be analyzed and each person has to determine if they think they are accurate and the weight that should be applied to each claim. I think single rail is the way to go, understanding that they are a little more dangerous... a little anyway. What irritates me is these Mfgs. that lie right on the sticker of the PSU about whether they are single rail or not. I think people should be able to decide what they want and get what they
