News
An Amazon storage space for developers
Published on March 14, 2006
Amazon Web Services today rolled out Amazon S3, a new storage service to help programmers house large amounts of data for their Web development projects. Read more
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
AMD Launches AMD Game For Change
Published on June 03, 2008
Amid all the Computex fuss it’s important to remember that outside of Taipei, the world goes on. It’s with this in mind that AMD today announced the launch of AMD Changing the Game, the first initiative from the newly formed AMD foundation. Read more
MIT's smart flying drones
Published on November 22, 2006
As recent events have shown, military forces around the world are more and more relying on small unmanned aerial vehicles (UAVs) for surveillance missions. Read more
Latest Reviews & Articles
Tom's Holiday Buyer's Guide 2008, Part 4
Published on December 02, 2008
Welcome to part four of our Holiday Gift Guide coverage. This time around, the Tom's Hardware staff picks its favorite components for your wish list rounding out 2008. Read more
4GB Gets Cheap: 9 Dual-Channel Kits Compared
Published on December 01, 2008
Recent price drops have made 4 GB DDR2 dual-channel kits affordable for even the most cost-conscious buyers. We pushed nine models to their limits to determine best value for a broad range of users. Read more
System Builder Marathon: Performance & Value
Published on November 28, 2008
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
System Builder Marathon: $1,250 Enthusiast PC
Published on November 27, 2008
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
  Tom's Hardware Forums » Overclocking » Motherboards » need oc help!
need oc help!
Word :   Username :
Bottom
Author
 Thread : need oc help!
"Couldnt think of one"
Profile: nimble knuckle
More Information
hey guys this is the rig i currently have:
intel core 2 quad q6600 @3.2ghz
msi p6n diamond (X-FI sound)
4gig of OCZ oc 900mhz
Nvidia gtx 260 sli @ 714/1240
I want to overclock my cpu to around 3.6ghz but i cant get it higher then 3.2ghz. Does anyone no how i can oc to 3.6ghz?
if this helps. cpuz says multiplier x9 bus speed 356mhz rated fsb 1425mhz.
Thanks!
intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 712/1260
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Related Product
Profile: Honorary Poster
More Information
Not all chips overclock the same, take for instance my E8400 which maxes out @ 3.8 where as others have gotten theirs to 4.2 or more. What voltage do you have it set at? Have you increased the NB voltage?
Message edited by ausch30 on 08-17-2008 at 06:58:07 PM
http://i192.photobucket.com/albums/z311/AUsch30/badge_wtp_02_3001.jpg
It is the mark of an educated mind to be able to entertain a thought without accepting it.
-Aristotle
More Information
well i have the go stepping and the temps says at 33c idle 50c load.
i think the mobo or ram is causing it not to let me oc much it further.
cpu voltage i put to 1.5v mem voltage 2.10v nb voltage 1.45v sb voltage 1.6v
Message edited by invisik on 08-17-2008 at 07:16:50 PM
Noob? Currently on Sabbatical!
More Information
And... whats the VID? Use Real temp, or Core temp to find out.
Knowing the VID will allow you to guess at the voltage required for a certain speed.
And then, a NVidia chipset board, that alone makes the over clock very hard to get done, when going for higher speeds.
To test your VDrop and droop, you need to hit the Bios, disable all spread spectrum junk, all CPU options, including C1e, Speed step, and EIST if you have it.
Then you check to see what you have the CPU voltage set to in the Bios, once you know its value, you can boot to windows, and after a minute to boot, check with CPUz and see what your windows Idle Voltage is.
Once you know this value, run Prime 95 small ffts torture test on all 4 cores, and after a minute of running, list the lowest value you see CPUz list your Core Voltage as.
The first is Bios VCore to idle windows, and reflects Vdrop. The initial drop in voltage from the Bios to windows idle.
The second is the further drop in voltage from idle windows to fully loaded on small ffts. That reflects VDroop.
Knowing these can easily let you know where the voltage parts need to be!
--Lupi
More Information
memory... you using 800 Mhz junk? At some point it will need to be changed. Go in the bios and put the memory mode to linked, and then the memory frequency to sync mode.
That way you'll need a 400 FSB before you even start to OC the RAM.
--Lupi
More Information
--Lupi
Exactly why is DDR2 800 junk? and why will it need to be changed? DDR2 800 is the fastest official speed for DDR so any memory sold at 1000, 1066, 1333 or whatever is really just 800.
-Aristotle
More Information
i dont think its a voltage issue. many ppl with this same mobo struggle to oc the board. i think its a issue with the board itself.
Google Ads
