I recently bought a Gigabyte 8800GT graphics card GV-NX88512HP rev 1 and within a few days of operation the computer started lock up with a pink screen. The only way to recover was to reboot the system. I have not altered the card in any way as it is already factory overclocked to 700Mhz. They appeared to have this problem with the original version of this card and subsequently changed several parts including swopping the Zalman V700 heatsink and fan for a V830. When I contacted Gigabyte techinical support they advised me to turn down the Core Clock to 600Mhz while they investigate the problem. My knowledge of graphics cards is limited but I chose rivatuner to try an accommodate their request. However, when I initially ran rivatuner before making any adjustments the following factory settings where displayed:
It looks to me as if the factory setting of this card were already set at 450Mhz and not 700Mhz as advertised. Am I misreading this or has Gigabyte delivered a batch of underpowered 8800GT cards that still don't work? Any help would be appreciated.
Try running a game and you should see these go to normal. I have the same card and was worried about that aswell, but its just saving energy and heat when your not using it. How do you work out what revision it is? I bought this card but it doesnt say whether it is r 1.0 or not.
As for the pink screen, maybe the card is faulty or you dont have enough power? What are your specs?
