News
NAND Flash Controller Makers See Demand Warming Up
Published on July 22, 2008
fter suffering from plummeting prices in June, NAND flash memory controller IC design houses are seeing an improved market demand status Read more
LSI to introduce enterprise SATA-II controller
Published on February 12, 2005
LSI Logic next week plans to unveil what it said is the industry's first enterprise-class SATA-II RAID controller. Read more
Germany preps 50 Mbit broadband
Published on March 10, 2006
Deutsche Telekom, parent company of T-Mobile USA, announced that it will begin installing VDSL2 broadband across Germany and will have the technology available in ten metropolitan areas by the end of this year. VDSL2 will offer download speeds of up to 50 Mb/s and uploads of up to 10 Mb/s. Read more
Samsung intros 8 GByte FB-DIMM
Published on December 08, 2005
Samsung to launched an 8 GByte version of its FB-DIMM memory series for servers. The module is built with 32 DDR2-533/667 devices, each with 2 Gbit capacity. Read more
Latest Reviews & Articles
Tom's Holiday Buyer's Guide 2008, Part 4
Published on December 02, 2008
Welcome to part four of our Holiday Gift Guide coverage. This time around, the Tom's Hardware staff picks its favorite components for your wish list rounding out 2008. Read more
4GB Gets Cheap: 9 Dual-Channel Kits Compared
Published on December 01, 2008
Recent price drops have made 4 GB DDR2 dual-channel kits affordable for even the most cost-conscious buyers. We pushed nine models to their limits to determine best value for a broad range of users. Read more
System Builder Marathon: Performance & Value
Published on November 28, 2008
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
System Builder Marathon: $1,250 Enthusiast PC
Published on November 27, 2008
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
  Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » Installing a fan speed controller
Word :   Username :
Bottom
Author
 Thread : Installing a fan speed controller
Profile: newbie
More Information
Hi.
I am in the process of putting together my new system in my new Lian-Li PC-A77 case. So far this is seeming like a nice case, it comes with a little LED display which connects to the case fans and lets you control fan speed / temperature via the display. Great idea, wiring it up has me confused.
The Lian-Li instructions seemed simple they were ( and i quote ) :
Step 1: Remove 2 screws to set up thermomemter.
Step 2: Put Battery.
Step 3: Done!
Now I am no expert on fan cooling but having unscrewed the display and put the battery i do not think that i am done.
In addition to the molex power connector the display has:
3 x 3 pin connectors labelled
- CPU
- sysf-f
- sysf-r
3 x Thermal sensors also labelled
- CPU
- sysf-f
- sysf-r
and a 2 pin connector that connects to the M/B to display hard drive activity.
My questions are:
What do i connect the 3 pin connectors to ? The labels suggest i connect one to the CPU fan, one to the front fan and one to the rear fan. But the Lian Li PC-A77 has 2 front intake fans and 2 rear output fans? what connects to what ?
Where do i affix the thermal sensors?
The 2 pin connector on the M/B for the HDD activity LED is already occupied by the connector for the orange case LED, i cant connect both to the same connector :(
Any advice people can offer on how to set this thing up would be greatly appreciated.
Related Product
Profile: old hand
More Information
http://www.ocia.net/fullsize.php?filename=308_23.jpg
Aren't yours labeled like in the photo? I believe there's a pass-through in each wire. Basically:
[cpu fan]---[cpu cable]---[fan controller]
You plug the cpu fan in the cpu cable. Look for a label on the cable or trace it to the circuit board. The rest don't matter. Could be psu fan or case fan.
As for the thermal sensors, they should be taped to the same part as the fan. i.e. cpu sensor to cpu heatsink. As close to the core as possible. It won't be as accurate as BIOS or core temp.
You tell me what I do.
Profile: Eternal Poster
More Information
the thermal sensor will be upto you where to put them as the temperature reported wont be accurate might as well put it at HDD Video card back and northbridge to monitor the accurate temperature. if there is not enough connector for all the fan just connect as many fans as you can or you can do some modding and connect 2 fan to one slot.
as i have said before if there is not enough connection leave it.
Profile: newbie
More Information
Thanks for the replies guys, yeah the wires are labelled like the picture.
So i connect the other ends of those wires directly to the fans instead of the molex connection.
The CPU wire is the one that confused me because the not so helpful instructions say "Fan controller for system fans only. Do not use with CPU fan". Then why is the cable labelled CPU >< ? Maybe its their way of saying "dont blame us if your CPU overheats"
I guess i'll put one sensor on top of the HDD and one at the top back somewhere. I wonder if there is some kind of cable that lets me hook two fans up to one
More Information
you will have to solder the 2 pair of wire together from 2 fans.
Profile: newbie
More Information
How about using a splitter cable like this ?
http://i12.ebayimg.com/04/i/001/04/d2/edea_1.JPG
More Information
yeah that will do if you dont mind paying
BUT
you fan controller might not handle it and end up blowing the controller.make sure power per channel is higher then the 2 fans add up together.
Profile: newbie
More Information
They are only 99p a pop :)
:( absolutely no information online or in the instructions on the power limitations, i guess i just chance it and see
More Information
yeah chance it since you wont blow a million pound hardware. you can always get a aftermarket fan controller thats looks and works better anyway.
Profile: old hand
More Information
If you monitor the cpu temp, you can leave the mobo cpu fan connector disconnected. That's what the case manual is implying. Some mobos won't post if the cpu fan is not connected. Mine is not either, but I monitor the cpu temp with core temp.
Google Ads
