News
An Amazon storage space for developers
Published on March 14, 2006
Amazon Web Services today rolled out Amazon S3, a new storage service to help programmers house large amounts of data for their Web development projects. Read more
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
AMD Launches AMD Game For Change
Published on June 03, 2008
Amid all the Computex fuss it’s important to remember that outside of Taipei, the world goes on. It’s with this in mind that AMD today announced the launch of AMD Changing the Game, the first initiative from the newly formed AMD foundation. Read more
MIT's smart flying drones
Published on November 22, 2006
As recent events have shown, military forces around the world are more and more relying on small unmanned aerial vehicles (UAVs) for surveillance missions. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
need help
Word :   Username :
Bottom
Author
 Thread : need help
Profile: stranger
More Information
hey i flashed wrong bios on my ecs p4m900t-m2 ver 1.0 motherboard.now it does not show the temp and fails to boot. the performance was good for some time. how can i flah my new bios. and i tried to flash again bit the applicaton says "flashing is not supported".need help fast
Related Product
There is ALWAYS a drone.
Profile: Ancient Poster
More Information
Will it boot from a floppy drive? Do you have one?
There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Profile: Forum Fixture
More Information
I took a look at your manual and it appears the only way to update your BIOS is with a floppy, is that correct? At any rate, it looks like you may to set a jumper and may need to set the BIOS to take the flash. Additionally you always need to default the BIOS after a flash. Don't do that if you know that it was the wrong flash, just try to flash the right one. If it won't take then default the BIOS and try again. If it doesn't take then you are screwed.
Here is the pertinent passage from the manual.
Quote :
Updating the BIOS
You can download and install updated BIOS for this motherboard from the
manufacturer’s Web site. New BIOS provides support for new peripherals, improvements
in performance, or fixes for known bugs. Install new BIOS as follows:
1 If your motherboard has a BIOS protection jumper, change the setting to
allow BIOS flashing.
2 If your motherboard has an item called Firmware Write Protect in Advanced
BIOS features, disable it. (Firmware Write Protect prevents
BIOS from being overwritten.
3 Create a bootable system disk. (Refer to Windows online help for
information on creating a bootable system disk.)
4 Download the Flash Utility and new BIOS file from the manufacturer’s
Web site. Copy these files to the system diskette you created in Step 3.
5 Turn off your computer and insert the system diskette in your computer’s
diskette drive. (You might need to run the Setup Utility and change the
boot priority items on the Advanced BIOS Features Setup page, to
force your computer to boot from the floppy diskette drive first.)
6 At the A:\ prompt, type the Flash Utility program name and the filename
of the new bios and then press <Enter>. Example: AMINF340.EXE
040706.ROM
7 When the installation is complete, remove the floppy diskette from the
diskette drive and restart your computer. If your motherboard has a
Flash BIOS jumper, reset the jumper to protect the newly installed BIOS
from being overwritten. The computer will restart automatically.
Google Ads
