ATI has a problem in the latest Catalyst drivers. Read more
A molecular switch that operates in a fundamentally new way could usher in a generation of microprocessors that work on the molecular scale. Read more
Artificial whiskers that mimic the way rats and seals sense their prey might one day let planetary rovers or uncrewed submarines explore the shape and texture of strange objects they encounter on their travels. Read more
Santa Clara (CA) - Last week, we learned that AMD has put the finishing touches on its external graphics platform, short XGP, and aims to be rolling out products based on the specifcation soon. Read more
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
| Bottom | |
| Author |
Thread : Strange problem
Profile: stranger
More Information
1st my spec
Related Product
Profile: nimble knuckle
More Information
Sounds like the PSU is iffy. Go to the PSU sticky and get a tier 2 or 3 replacement PSU.
Profile: Eternal Poster
More Information
You need a graphics card to run games well.
--------------- Scruze my English! |
Profile: old hand
More Information
Sounds like a heat issue to me; have you had a look inside your case to see if the vents and grills are clogged in dust? |
Profile: stranger
More Information
Hi, thanks for the replying.
Profile: stranger
More Information
My psu is mercury, model AP-2400
Profile: Forum Veteran
More Information
Lets see.. you could: 1.) Set XP to stop on the blue screen to see what details or error numbers that it comes up with. Which is done by bring up system properties, then advance tab, then click on settings for startup and recovery, uncheck automatically restart. 2.) Check the event viewer, I'd look at the system events for hardware problems, or application for any software problems. You can also click on the hyperlink for additional info from MS to see if it can help you out, when your viewing the event. 3.) Double check on the memory spec's. Sometimes the bios will automatically set things up on the memory timings and voltage. If the timings are too tight, or not enough voltages, those things could cause instabilities.
Message edited by Grimmy on 02-26-2008 at 03:59:22 PM |
Profile: member
More Information
how long have you had this problem?
Profile: stranger
More Information
i've this problem since i bought it.
Profile: member
More Information
it really sounds as chipset overheats after a while of 3D use, or the Pc itself needs more power when doing 3D and that causes a crash due to Power supply instability.
More Information
You should replace that power supply with one that has 16-18 amps on the 12v rails. Your power supply is barely making it.
Profile: stranger
More Information
OK guys, thanks for replying.
More Information
Thermaltake less than 600 Watt is not a good brand (Tier 3 or 4), but better than what you have now.
Profile: member
More Information
well, depending on pricing, the thermaltake could make a better job than your actual PSU. Still, I have antecs and sharkoons and they do a nice job. But if you want to deepen your reasearch theres a PSU stress test available somewhere in toms hardware testing galore. ---------------
Profile: stranger
More Information
[quotemsg=1796727,7,61626]Lets see.. you could:
Message edited by nasim_30 on 03-03-2008 at 07:09:48 PM |
More Information
