News
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Microsoft fixes critical IE problems
Published on December 14, 2005
Microsoft this week fixed a widely reported flaw in its Internet Explorer browser that had been used by attackers over the past few weeks to take over the PCs of unsuspecting users. Read more
Shuttle announces SD39P2 barebone XPC
Published on March 01, 2007
Shuttle announced on February 27 the XPC SD39P2 barebone, the company's atest small form factor PC supporting Intel's socket 775 processors, including the Intel Core 2 Quad, Core 2 Duo and Core 2 Extreme series models. Read more
E-voting worries focus on failures, not fraud
Published on November 10, 2006
Major electronic voting machine problems occurred in at least six U.S. states during the country's midterm elections, underscoring that system failure, not fraud, is the biggest issue facing future races, voting-rights activists and technologists said this week. Read more
Latest Reviews & Articles
Core i7: 4-Way CrossFire, 3-way SLI, Paradise?
Published on November 04, 2008
For the first time ever, gamers are being treated to a reasonably priced platform enabling the best that AMD and Nvidia have to offer. Is Core i7 a gamer’s nirvana or does the processor serve up more of the same? Read more
Editor's Corner: Overclocking Core i7
After discovering Intel's Overspeed Protection in yesterday's first-look at Core i7's performance, we're back to set the record straight on the overclocking headroom of the flagship 965 Extreme and entry-level Core i7 920. Read more
Intel's Core i7: Blazing Fast, But Crippled O/C
Published on November 03, 2008
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
8800GTX problems
Word :   Username :
Bottom
Author
 Thread : 8800GTX problems
"Hmmmmmm"
Profile: Honorary Poster
More Information
After 9 months of serving me loyally my GTX is finally starting to show problems. My computer freezes on one frame and doesn't move until I restart then when I restart I see artifacts all over the place and freezes after about 2 minutes of use. I updated the driver before it froze again. Check temps maxxed out at 70 while playing oblivion. Shouldn't been temp problems. No power problem TT Toughpower 750W. So any suggestion to what is wrong would be nice.
It's a theater of love stories.
Related Product
"Hmmmmmm"
More Information
bump
Profile: member
More Information
Is your PC overclock? Try to setup it up with normal clock speed and check if it goes away. That will give you some clue
"Hmmmmmm"
More Information
No overclocks orginal settings
Sniper
Profile: Forum Fixture
More Information
Could be driver problems or game itself (corrupted installation/file?). Try reinstalling the drivers also check that the power cables are not lose,etc.
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
"Hmmmmmm"
More Information
Did all.
Profile: addict
More Information
RMA the card.
Asus P5B Deluxe, Core 2 Quad Q6700, Nvidia 8800GTS (G92), Corsair 4GB PC2 6400, Sound Blaster X-Fi Platinum, Thermaltake 700W PSU
Profile: Faithful Poster
More Information
I just bought my 8800GTX last November and it runs just as cool (51C idle and 70C playing Crysis) as my last card, the 7800GTX. I also noticed that my overclock was a bit above what I expected to get 651MHz core, 1525MHz Shader and 2100MHz memory. I also experience sometimes when my PC loads to desktop it will show color corruptions in the same place everytime hardlocking my PC, the only thing I can do at this point is power off.
This doesn't happen often though, could be driver related or something completely different. Have you ever cleaned all that dust in your GPU cooler? I bet its caked with dust in there. Try this Burnin test 5.3 at www.passmark.com
I helped someone last month with some video corruption issues on 2D only and this Burnin Test 5.3 told him that his graphics card was having trouble processing 2D which is what he was saying while in BIOS also. Give it a try and let us know whats up.
Message edited by systemlord on 02-14-2008 at 12:33:24 PM
Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Jesus love boobies too.
Profile: old hand
More Information
I have seem with the 8800 GTX will overheat and then shut the video card down other then the fan in order to cool it down. The artifacting sounds like it is cause by heat issues. My 8800 GTX originally ran over 75c idle and over 100c at load. Now for what ever the reason (nothing has changed in the case) after installing newer drivers I idle around 49-55c and load at 80c.
I think your card is broken and or needs a better cooler on it. Might I ask what brand is it?
And on the third day, God created the Remington bolt-action rifle, so that Man could fight the dinosaurs. And the homosexuals.
Google Ads
