Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > System will not power on
Forum Homebuilt Systems : General Homebuilt - System will not power on
I recently built a new rig...and I went to plug in a headset for Skype. As soon as I inserted the microphone jack into the "microphone IN", the system shut off and will not boot up. I didn't not see or hear any sparking. I'm wondering what steps I should take to get the system working. I have:
1. Unplugged system
2. Waited over an hour
3. Flipped the PSU I/O switch.
I don't get anything. No lights, no fans, nothing. Any ideas?
Sponsored Links
I would clear the cmos, then if it boots up, check all your connections and everything, make sure you mobo or no wires are up against the metal parts of the case. Kinda sounds like you have a short somewhere.
Reply to ohiou_grad_06
I'd check all the connections first, and the mobo mounting. Disconnect everything from the PSU except the mobo and video card, see if it posts. If there's a short, the PSU may have shut off to save itself or your system.
Worst case, your mobo is cracked somewhere, maybe around the rear I/O ports.
(can't resist) I'm assuming that step 2a was to plug the PSU back in.
Were there any fan twitches, including the one in the PSU?
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
I'm not home now...I'll check these things tonight. Thanks!
Reply to singingigo
Additional steps:
1. Clear CMOS
2. unplug all power i/o on board.
3. use power supply with another MBO (it works just fine)
4. checked green MB LED to indicate power to board (comes on when plugged in).
I think it's narrow down to two things:
1. bad mbo (order GA-P35-DS3L from NEgg)
2. Bad switch...highly unlikely since the only way the switch could have been affected would be for a electrical spark from the headset jack to the power switch, which would require the spark to travel across the bottom 1/3 of the mbo...
Any other ideas?
Reply to singingigo
Disconnect the power switch, and short the pins with a screwdriver. If it doesn't work, RMA the board. If it does, check the front panel switch and its wiring. I just replaced a case because the drone who assembled the prior one put a screw through the power-switch wires, causing an intermittent short.
Reply to jtt283
There are 679 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
