News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Xandros gets Windows personality via Versora
Published on June 19, 2006
Desktop Linux vendor Xandros has teamed up with migration software vendor Versora to ensure that its forthcoming Desktop operating system is able to adopt users' Windows. Read more
Linux supporters deliver desktop standards
Published on April 25, 2006
The Free Standards Group is due to launch version 3.1 of its Linux Standards Base, delivering the first fruits of its LSB Desktop Project to create new standards for Linux on the desktop. Read more
Dell readies AMD-powered desktop?
Published on June 15, 2006
Dell is gearing up to release a desktop PC powered with a microprocessor from Advanced Micro Devices in September, according to analysts at Wall Street brokerage house Citigroup. Read more
Latest Reviews & Articles
Intel's Core i7: Blazing Fast, But Crippled O/C
Published on November 03, 2008
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
New Desktop problem
Word :   Username :
Bottom
Author
 Thread : New Desktop problem
Profile: stranger
More Information
I am not sure whether this is the correct forum to raise the issue but I have no clue regarding this problem in a week old new desktop (Biostar M4890 SE mobo, 1.8 Mhz conroe chip, 2 GB RAM, 160 GB SATA hdd running Win XP) except that this is definitely a hardware issue.
Symptoms are
1. If I try to install (any) software, suddenly it says it can't read a file in the installation package. Sometimes any native windows application like task manager, services.msc does not start up saying sorry. If I restart the machine, everything works fine till again it starts misbehaving at some point in time.
2. If reboot does not stabilize things, I do chkdsk and it corrects lot of files always and finally says no bad sector in the disk.
3. Initially the problem was with XP SP2. I formatted and installed XP SP1 and same things started all over again right from the word go.
4. Interestingly, no BSOD till date but situation is not much better though.
5. memtest (ran for 3 hours, sometimes fails in random 20 test), WDM (ran for 6 passes, failed once in stride test). I upgraded memory from 1GB to a single 2GB stick and it had no affect on anything. The symptoms were same with both the sticks. So, memory may not be at fault.
6. Seagate test (Seatools for windows) does not show any problem with the disk.
7. Orthos (Small FFT passes) blend test fails almost instantaneously (8-10 seconds).
8. smartguardian (a hardware status tool) shows (not sure what to interpret out of it, though)
cpu temp: 23C
vcore voltage: 1.16V +5 5.13V
vcc3: 3.15V +12 12.16V
vbatt: 3.31V
I have never dealt with hardware and have no clue. Any help will be greatly appreciated. Let me know what all information I should provide regarding the system.
Thanks for all the help and time....
Related Product
Profile: old hand
More Information
So you have tried 2 different sets of ram and the both fail? Have you changed anything in the BIOS or is it all at stock? From your ram test failures I would tentatively guess a MB issue, but it could be as simple as a BIOS setting is a little too aggressive. Sometimes ram requires tweaking in the BIOS (it is not detected properly) before everything runs as it should.
Gaming: FX-60 @ 2.81GHz (x14, 1.375, 90nm) > A8N-SLI Deluxe > Asus 4850 - 625/1986 > 2GB Corsair XMS 400MHz
2-3-3-6-1T
HTPC/Light Gaming: X2 5400+ 2.8GHz Brisbane > Gigabyte 780G MATX - 900MHz Core > 2GB Corsair XMS2 800MHz
4-4-4-12-2T
Profile: stranger
More Information
Thanks for reply...
yeah, I tested with 2 sets of RAM and 2 different OS with same set of instabilities in both. But, 2 things I did only yesterday, which seemed to improve things a lot, at least, for last 24 hours. I changed the power settings in BIOS to 'Max Savings' instead of 'User Defined' (though, I never defined one to start with) and this time, I did not put any driver that came with mobo (other than audio). That seemed to improve stability of the system a lot but need to see it for a longer duration...
Google Ads
