Where is the problem
Forum Homebuilt Systems : General Homebuilt - Where is the problem
I have build two identical computers the parts are:
mb: asus maximus formula
cpu: Intel E8400
gpu: gainward 8800 gt
memory: corsair pc 6400 2x2 gb
hd: western digital 500 gb
one works great, but the problem is with the other.
First i installed vista-64, but it was very unstable, first time it crashed when I was installing drivers for motherboard. I tested with another cpu (celeron 1,6) but it was still unstable, so I used the celeron and flashed the bios to 0907, but the windows was still unstable, and with blue screens. Then I changed back to E8400, and install vista-64 again, but it was very unstable, sometimes i could run 3dmark06, then i tried it again with blue screens. I tried to take of one of memory modules, it did't help, then I tried the other, still the same. Then I try to install the operating system again, but from now on little before it finished i got blue screen, i tried with different hard drive, different graphics card.
Then I think i was the motherboard, so I send it back, but today I got e-mail from them, and they tested it without problems.
So what more can I test?
Sorry for my bad english.
Sponsored Links
Vista 64 bit is probably your issue.
Are you installing 64 bit drivers for all the hardware?
Reply to rgeist554
Yes, but I don't get to windows any more, and the other system which is identical works fine. I have all the drivers for vista-64. But I get blue screen before it has finished installing windows, usually where it finalize the installations and the last restart.
Reply to zosma
Have you tried swapping memory with the PC's since they are identical. Also, make sure your BIOS has the correct voltage settings for the ram you're using. (Usually it's like 1.8v, but some RAM requires 2.2v)
Reply to rgeist554
I had a very similar issue with my striker/vista64 first time, it was the Memory…
I don’t suppose you have a 1gig stick available?
In the end for my issue I had to install with 1gig Ram, then add the others 1 by 1.. It took me forever to figure it out.
*edit*
Microsoft made a patch
http://support.microsoft.com/kb/929777/en-us
Message edited by grieve on 02-06-2008 at 11:55:44 PM
Reply to grieve
Yeah, stuff like that is a pain. After a while, I've come to the conclusion that most BSODS are RAM related. It's not true all the time, but usually it ends up being the issue.
Reply to rgeist554
I took the memory att put in the other computer, and they works great in it, so it is not the memory either.
Reply to zosma
Reseat your CPU. Maybe you are overheating.
Reply to roadrunner197069
Why use Vista at all?
XP w/SP2 built in is $89 USD and is faster than Vista and has no problems.
Also if both systems are the same CLONE the working systems HD and see if you still have a problem with the non-working one.
Also clear the bios on the bad one.
Message edited by ZOldDude on 02-07-2008 at 08:07:29 AM
------------------------------ *While we crash and burn, small, low tech, agrarian societies such as the Hmong in the mountains of Laos will continue on without so much as blinking an eye.*
Reply to ZOldDude
try swapping psus,then cpus.or rebuild the defective rig outside of the case to eliminate the chance that the mb is shorting into the case.
Reply to maxfly
I test some more things when i get back the motherboard, if I can't find the problem then, I will go back to the store with all the components, the good thing is that they came all from same place.
Well I like vista a lot more than xp, I don't ever want to downgrade back to xp.
Reply to zosma
What PSU do you have for both computers and are they the same? A faulty or bad PSU can cause a lot of instability and is the most important component for your PC. Heres something you should have a look at.>>
http://www.tomswiki.com/page/Tiere [...] ngs?t=anon
------------------------------ Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Reply to systemlord
Is Vista 64 bit on both computers?
Reply to bobbknight
Vista 64 is (or should be) on both computers.
Psu is Silver Power 600 w and the both computers have the same model.
Reply to zosma
You have the ideal situation - two identical computer builds, one works but one does not. Leaving only the mobo, cpu, and cooler in each machine, swap ALL other parts.
If the same machine fails, its the mobo, bios settings, processor (rare), or the way the mobo is installed in the case (shorted, etc).
If the previously working machine fails, its the memory, psu, or OS installation on the hard drive (unlikely).
If both machines now work, sell them quickly :)
Reply to Twoboxer
Yes but i have tested with different gpu, hd, the memory is now on this working machine. Even different cpu. The only thing i don't have tested is dvd-burner and the cables for dvd and hd, and psu.
I have send back the mb, but in the store they tested it, and they say that it works fine. bios i have resetted many times. But when I get back the mobo, I test some more, if it don't work, then I take all the parts to the place of purchase. So they can find what the problem is.
Reply to zosma
Is that a beta bios?
Tray reflashing the bios in any case.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Try 1 stick of the Ram from the other computer...
** I understand there is nothing wrong with the ram, but perhaps for what ever reason it is just being picky during install.
Reply to grieve
when i get it back, i use the ram modules which was att the beginning in this working machine, because i put the memory modules from the other to this one, i didn't feel to change them back again, because they are the same.
the bios is 0907 in both, the reason i flashed was because otherwise there came everytime unknown cpu.
Reply to zosma
I think I will test tomorrow the gpu in this working machine and perhaps the hd and install windows on that, because the other system is exacly the same. If they work, then there are less possible faulty components to look at.
Reply to zosma
Now I purchased a new motherboard and it seems to work fine.
Reply to zosma
When I have installed windows then I installed the drivers for motherboard. After it has installed the chip drivers, the computer reboot, the it ask if I want to make raid disk, there is three choices 32 bit, 64 bit or dos. But if I don't want to make any disk, how can I proceed. If I restart I came to same place, with maximus formula, I resetted the bios, then it worked, with this new motherboard, I flashed the bios, and after that it worked. But there should be some easier way.
Reply to zosma
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Where is the problem
There are 1048 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
