Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Can a NOX 600W Power Supply handle the following system?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Can a NOX 600W Power Supply handle the following system?
1. Mother Board: ASUS M2N-E SLI
2. CPU: AMD X2 4800+ Brisbane BH-G1
3. DDR: 2 x 1GB Corsair XMS2X1024-6400
4. POW GeForce 8800GT 512MB GDDR3
5. DVD-Rom LG 16x
6. DVD-Writer SAMSUNG 20x
7. HDD: 2 x Seagate 250GB SATA-II
8. 4 x 12cm COOLING FANS (4x12v) (excluding the CPU one)
9. *** Later I will UPGRADE another pack of Corsairs 2X1024, so please take this in count.
THANKS!! Alex :bounce:
Sponsored Links
I've never heard of the NOX brand. I did follow some Google links though, and found this statement:
MTBF: "100.000 Hrs at full rated load, 120Vac input & 25ÂșC"
25C is an unrealistic real-life working temperature for a PSU, and suggests that the ratings on this one are not to be trusted.
A 450W or higher model from Tier-3 or better from the list at http://www.tomswiki.com/page/Tiere [...] ngs?t=anon would probably be a safer choice.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Most certainly yes. I have a very similar setup except the cpu is e6750@3.2ghz 4gb ram and a HIS 3870 ICEQ3 with 2 dvd writer drives, soundblaster audigy 2zs all running no problem at all on a jeantech 600w psu.
Reply to tcn31
thanks guys, the supply is nox 600watt "urano series" and has a good look, i mean it's heavy and the cooler on it works very well.. and it comes prepared for SLI :P
Reply to Nattefrost
Check the sli certification though as some manufacturers fail to submit them to Nvidia and just claim that it is sufficient for SLI.
Reply to spanner_razor
There are 1107 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
