News
Microsoft to introduce Windows Live Family Safety Settings
Published on March 14, 2006
Microsoft will be rolling out a new web-based service designed to help parents protect their children from unwanted online content. Read more
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
MIT researchers developing a quarter-sized turbine engine
Published on September 20, 2006
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
PhD Student Makes World's "Most Advanced" Walking Robot
Published on May 23, 2008
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
Latest Reviews & Articles
Intel's Core i7: Blazing Fast, But Crippled O/C
Published on November 03, 2008
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
  Tom's Hardware Forums » Motherboards & Memory » Memory » OCZ on GA-P35-DS3P Settings Help
Word :   Username :
Bottom
Author
 Thread : OCZ on GA-P35-DS3P Settings Help
Profile: journeyman
More Information
Hi All,
I need some help for my latency settings for
OCZ REAPER - P6400 -800 on A GA-P35-DS3P Bios F7
It as auto set my 8GB [ 4X2GB]OCZ REAPER RAM to 6-6-6-18
I know 8GB is harder to lower but can someone explain what CPU-Z says about it aswell
CPU-Z Says 6-6-6-18 2T Symmetric.?
I know the Ram will go lower its advertised as 4-4-4-12 or 15, what can i set it to, and will it help ect.
Related Product
Profile: addict
More Information
man, u need to use the search button. or browse a bit. coz it would solve many problems.
anyways, here is a link. http://www.tomshardware.com/forum/ [...] erclocking
Q6600 @ 3Ghz | zalman 9700NT cooler | gigabyte P35-DS3L | Kingstone DDR2 667 1GB x 2 | HIS 4850HD with Accelero S1 Rev.2 | enermax Liberty 500w | Coolermaster C5 case |
Profile: old hand
More Information
Exacly what version of the OCZ Reaper do you have, the CAS3 or CAS4?
You have to manually set the timing in the BIOS (CTRL+F1, then go in the MIT menu). I got the CAS4 version on the exact same board on DS3L, but I couldn't get it to be stable at 4-4-4-15 @ 400MHz with 2.1V and I have no idea why, I haven't even tried to overclock yet. I posted a message on OCZ's forum to see if anyone could help, but no news so far.
If you have better luck, please let me know.
Message edited by Zenthar on 03-24-2008 at 05:05:44 PM
The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
http://valid.x86-secret.com/cache/banner/337014.png
Profile: journeyman
More Information
I dont have the same board that you have i have the ds3r but the memory voltage increase isnt linear from what Ive seen so I had to set it a little higher like 2.3 in the bios and have been able to get that cas4 settings stable.
Profile: old hand
More Information
Tried up to 2.3V also but still unstable. It seems it might be my DS3L that doesn't like 4-4-4-15 timings @400MHz :/.
Google Ads
