Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Power Supply of choice for my build??
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Power Supply of choice for my build??
Profile: journeyman
More Information
Hey so i know the minimum i need for my new build is 620 Watt, but i have no idea which one to get.  I am either putting it in an antec 900 case or the antec p182 case.  I know both of these have problems with power supply cables not being long enough, so i was wondering what would be a good power supply for this.  Keep in mind this is a budget build, so i am hoping for not going over 130 for the psu.  Also are there any good modular for this price to clear up some cables?
Related Pr oduct
Profile: addict
More Information
Hi
I am helping a friend buildup an Antec P182 case. The Hiper 780Watt PSU is expensive but one of the cheapest Tier 2 PSU's
(http://www.xtremesystems.org/forum [...] p?t=108088) I am aware of. It fits in the P182 case - just!!
BTW I am refering to:
http://www.ebuyer.com/search/?intS [...] atUID=1585
for pricing which will of course be different in the USA!!
The Enermax Liberty range are cheaper and also Tier 2. I am currently playing with a 400Watt model for another build for a guy at work. However the modular cables aren't quite as neat as the Hiper range.
You can of course get something cheaper... But the PSU is not where you should be saving money.
Bob
Profile: enthusiast
More Information
just buy an extension cable.
Message edited by bob8701 on 03-01-2008 at 11:58:53 PM
Profile: newbie
More Information
How do you know that you need 620W?
[x] post specs.
Profile: journeyman
More Information
Q6600
MotherBoard Undecided, most likely going with a P35 Chipset Though
4gb ddr2 800 OCZ Reapers in 2x2gb Setup
8800gt MSI
BluRay Drive
2*DVD RW Drives
Possibly up to 4 HDD (500-1TB in Size)
Arctic Cooling Fans
Antec 900 or possibly p182
Profile: journeyman
More Information
Oh and Possibly adding in a Creative Xifi Card
Profile: old hand
More Information
Opinions are like asses,everybody has one.
Profile: addict
More Information
That PSU is Tier 2 and has a good reputation!!
Bob
Add a reply
Google Ads
