Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Using a CM 690 case for my first build
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Using a CM 690 case for my first build
Profile: journeyman
More Information
I'm going to be building my first PC soon, but one thing has come to my attention: My CM 690 case (which I already bought since I got a good deal on it) has no motherboard speaker inside.  If I put my PC together and it doesn't POST... how am I supposed to figure out what's wrong, with no beep codes?  Is there something else I can do to figure out where I went wrong, if I run in to issues?  I'm using a Gigabyte GA-EP35-DS3P motherboard in my build, if that helps.
Also, is there any way I could say... rip a speaker off an old motherboard from an old computer, and use it with my new one until I get it up and running?
Related Pr oduct
"STEEL SHOT SUCKS"
Profile: member
More Information
Hey, had same prob...took out spraker fron old at case... never beebs anyways! Good luck!
e6750(stock cooling)@ 3.4GHz(425Mhz bus)|GA-P35-DS3L|2x1 Patriot Extreme Perfomance DDR2-800(6400LLK)@850MHz 4-4-4-12 Dual Channel|BFG 8800 GT OC2|WD Caviar 16/500mb|LG GSA-4167B DVD Burner|Corsair HX-520|Viewsonic E70 17" CRT|Coolermaster CM 690
Profile: nimble knuckle
More Information
go to Radio Shack and buy a small speaker and connector for a couple bucks if your really worried about it.  I have a Cooler Master case and I don't have a speaker either, I was never really concerned about it.
Quote
"Wit is educated insolence."
-Aristotle
Profile: addict
More Information
Over here in the UK, it's almost like they don't exist anymore!
If you really need one, I have no idea where you go for one, but fortunately I had no problems!  :)
6000+ Stock, GA M57SLi-S4, XFX 8800GTX's SLi Stock, 4Gb Corsair PC6400 DHX, CoolerMaster 850W, 36Gb Raptor boot drive, 2x150Gb Raptor's in RAID 0 - XFX RAID controller & 300Gb Seagate. PowerBook G4 12" 1.5GHz, Go5200 64mb, 768mb RAM, 80Gb HD, SuperDrive.
Profile: journeyman
More Information
I see... We do have a Radio Shack here, so I'll probably go there and look for a speaker if I run into problems.  Thanks for the advice.
Add a reply
Google Ads
