Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Possible monitor driver issue
Forum Graphic & Displays : TV/Video Cards - Possible monitor driver issue
The maximum resolution I can select for my screen, using windows control panel/games is 1280 x 1024, but when I ran 3Dmark06 tonight, in the log file created it lists my screens' maximum resolution as 1600x1200. Could this be because I don't have the right driver? The control panel simply sees the screen as a 'plug and play monitor' with no other details. As for which screen it actually is, I don't know. It came with the PC I bought an there is no manufacturer name/model on it. It is connected through D-Sub, through a Radeon 9550.
Oh, and just in case you want to know, my 3D score was 568 :D! But I only did it so I can see how this beast stands up to my new rig, which thankfully, is almost ready.
Thanks for any help!
Sponsored Links
I'm guessing you have a 17inch non-widescreen LCD hooked up to it. If that's the case, almost all 17inch non-widescreen monitors use a resolution of 1280x1024.
Reply to IndigoMoss
It would appear to be a 17", and it's definitely not widescreen. Thanks for the quick response.
Reply to Viper9201
There are 687 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 TH won the Freshman badge
  • 01:00 exploresalot won the Freshman badge
  • 01:00 mlg779 won the Freshman badge
  • 05:31 Mysteic won the Sophmore badge
  • 01:00 listerd won the Freshman badge
  • 01:00 stephen98146 won the Uniformed badge
  • 01:00 LANKO1982 won the Uniformed badge
  • 01:00 sitec won the Uniformed badge
  • 01:00 iiraymoii won the Freshman badge
  • 03:27 cjl won the CPUs badge
