Taipei (Taiwan) - While walking the halls of the Computex trade show, we saw this interesting power supply with an integrated watt meter. Read more
For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
Tom's Hardware Forums »
CPU & Components
Power Supplies, PC Cases & Case Mods »
Power Supply Requirment Question
| Bottom | |
| Author |
Thread : Power Supply Requirment Question
werd.
Profile: addict
More Information
I am going to build a new rig soon, and I am going to need a new power supply. My new rig will be: Intel Core 2 Duo e8400 I used the eXtreme Power Supply Calculator at http://www.extreme.outervision.com/PSUEngine --------------- "Engineers, close in and shoot those kraut bastards in the face!" E8400 @ 3.6GHz (9x400FSB 1.32v)|4GB|HD4870 |
Related Product
Overclocked and Undervolted
Profile: Honorary Poster
More Information
Your system will never draw much more than 300W even with the upgrades. Power supplies are generally most efficient at around 50-60% load. Look for a quality 450-550W model such as the CORSAIR VX450. |
3.8 ghz at 1.2v? More likely..
Profile: member
More Information
The difference between most efficient and least efficient load is 2-3% on quality 400w-500w 80+ models. --------------- 3.8ghz Pentium D loading at 43C? What? |
Profile: Forum Veteran
More Information
Newegg's PSU calculator is even worse than Outervision.
--------------- Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | X1900XT 512MB | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi | WinXP There is no such thing as a stupid question. But there are stupid people. |
werd.
Profile: addict
More Information
Hmm, if that's the case, then could I still use the power supply that I used to power my old rig? It is this item: http://www.newegg.com/product/prod [...] 6817182022
More Information
There is a reason Rosewill power supplies are so cheap. Go with the Corsair VX450 that I linked above. You won't regret it. |
werd.
Profile: addict
More Information
Maybe I will go with that, but not right now. Perhaps when I upgrade to a 8800GT. Now my main question is: will my current power supply be suffice? --------------- "Engineers, close in and shoot those kraut bastards in the face!" E8400 @ 3.6GHz (9x400FSB 1.32v)|4GB|HD4870 |
More Information
I would love to tell you yes, but I don't want to be responsible if your system fries. If you are looking for something cheap that will get you by even if you upgrade to the 8800GT check this out:
I hate titty tats.
Profile: Honorary Veteran of THGC
More Information
I have found this article http://en.wikipedia.org/wiki/Computer_power_supply helps people who have questions about the size of power supply needed for DIY personal computers.
--------------- Doctor Hooter Boobs Boobs Boobs...who loves boobs?...I do I do |
werd.
Profile: addict
More Information
How about this one? Would it last for future upgrades aswell? Like an 8800 GT or better, more RAM, hard drives, etc? It's way more expensive then I would like :| http://www.newegg.com/Product/Prod [...] 6817151040 Message edited by doomsdaydave11 on 03-05-2008 at 03:26:55 AM --------------- "Engineers, close in and shoot those kraut bastards in the face!" E8400 @ 3.6GHz (9x400FSB 1.32v)|4GB|HD4870 |
Profile: old hand
More Information
Check out jonnyguru.com, I'm not sure which ones, but he has given his blessing to a couple of Rosewill PSU's. Don't go strictly by Newegg ratings and customer reviews and don't 'put a price' on your power supply, you can set a budget but don't say 'I'm not spending over $X amount. Systems need stable, clean power output, especially when you start adding GPU's that need power and you start overclocking, which leads to overvolting, if you will. A difference of say $20 may get you something better. A couple of weeks ago, buy.com had the Corsair VX550 for $50 after rebate and google checkout and that was a steal. This is just as good a deal on the HX 520 that's modular.
Message edited by chuckm on 03-05-2008 at 03:44:51 AM --------------- Opinions are like asses,everybody has one. |
Life Is What You Make Of It
Profile: journeyman
More Information
I myself chose a 600W PSU knowing it was more than I needed today, because it would allow me to connect two video cards and power what I was running in the future. It may be a better idea to get the biggest PSU that you can comfortably afford... that way buying some security for the future too. They are cheap to begin with and nothing worse than having to spend double the money in the end to get two different PSU when could have bought one in the beginning that was good enough for future expansion. Good to also look for a long warrenty term too... mine was three years. --------------- Acer AM5620 Intel Q6600 2.4 Ghz Quad Core with 4GB 6400 Ram, 4x500 GB Hard Drives, Thermalright IFX-14 Cooler, and Cooler Master Cosmos 1000 Case. (Video Editing/Game Machine) |
CPU & Components
