Tom's Hardware > Forum > Overclocking > Motherboards > E1200 Overclocking help
Forum Overclocking : Motherboards - E1200 Overclocking help
Quote :
BIOS 001 - http://i33.tinypic.com/ng9649.jpg
BIOS 002 - http://i38.tinypic.com/29xt7iv.jpg
BIOS 003 - http://i36.tinypic.com/24xdwyt.jpg
BIOS 004 - http://i38.tinypic.com/kb6skl.jpg
BIOS 005 - http://i33.tinypic.com/jpxvl1.jpg
BIOS 006 - http://i38.tinypic.com/akbacn.jpg
BIOS 007 - http://i37.tinypic.com/16b0ih0.jpg
My Computer - http://i36.tinypic.com/eivybd.jpg
Overclock - http://i38.tinypic.com/i3hso4.jpg
My Spec's
Biostar P4M890-M7 SE Motherboard
Intel E1200 Dual Core Celeron (1.6GHz)
1 x 1GB OCZ Gold PC2 5400 RAM (Temporary)
2 x 1GB Corsair XMS2 RAM (Coming in Post)
Nvidia 7600GS 512MB PCI-E Graphics Card
Win Power 650W Modular PSU
World Records - http://www.ripping.org/database.php?cpuid=670
OK, heres the problem! I've got a 'supposedly easy overclocking rig' but I'm only able to get it just over 2GHz
Please could somebody help me?
Sponsored Links
what kind of mobo is that i dont even think its compatible with that CPU?get a P35 mobo it will OC well.
that mobo is for all those old pentiums and the chipset is barely capable of having it on.
Message edited by iluvgillgill on 08-30-2008 at 07:11:59 PM
Reply to iluvgillgill
Quote :
P4M890-M7 SE SOCKET 775
• Processor:
Socket LGA 775
Supports Intel Core 2 Duo/Pentium D/Pentium 4/Celeron D Processor
Supports FSB 1066MHz
Support Intel Hyper-Threading Technology
http://www.biostar-usa.com/mbdetai [...] 90-M7%20SE
Seems fine?
Reply to robmozza
i know it says support it. but i dont think it will work in OC anyway since max support is 1066 and when it was first designed it wasnt designed for these high speed chip anyway. you need a new mobo definately!no doubt about it.
OK, thank-you, I do appreciate your help.
But, is there nothing more I can do with this current mobo to squeeze out some more MHz?
And what newer mobo would you suggest please?
Reply to robmozza
have you increase all the relavent voltage already to get that OC?
You wont get much more out of a crappy motherboard like that. You will probably never get over 3.2 even though a few others have.
3.2 will be very capable on a P45 mbo like Asus P5Q pro.
Reply to roadrunner197069
P35 can also do it. since the whole setup is base on a budget style.no good going for expensive P45 specially Asus-premium brand.
hmmm, so I guess it's time for a new motherboard then!
One final thing I've been trying was to reflash the BIOS, it kinda back fired on me though (as I was hoping to get more of an OC) and I ended up getting less :(
http://i34.tinypic.com/10d8al1.jpg
http://i33.tinypic.com/2zps2dy.jpg
Right, thanks for all your kind help and suggestions guys. I'm giving up with this mobo! :D About bloody time as well!!!
Reply to robmozza
There are 1140 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
