News
TSLI intros low-jitter, high-frequency PLL clock multiplier IC
Published on September 30, 2004
TSLI today announced a very-low-jitter, high-frequency PLL clock-multiplier IC, the T98553, that is designed to replace high-cost crystal oscillators for use in serial data communications market. Read more
Mobo makers: Intel's dual-core Presler has stability issue
Published on November 15, 2005
Sampling Intel's 65nm dual-core Presler processors has revealed some stability problems, according to unspecified motherboard makers. Read more
GeCube Launches RV635 And RV620 Graphics Cards
Published on January 24, 2008
GeCube has launched its Radeon HD 3600 and 3400 series graphics cards targeting the mid-range and entry-level markets. Read more
SuperTalent announces Project X
Published on January 11, 2008
In addition to its current line of SSD products, SuperTalent was showing off its new, low-latency high-speed DDR3 sets, branded "Project X". Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
  Tom's Hardware Forums » Overclocking » CPUs » Please help (Have problems with CPU Frequency-Multiplier stability)...
Word :   Username :
Bottom
Author
 Thread : Please help (Have problems with CPU Frequency-Multiplier stability)...
Profile: stranger
More Information
Hello everyone. I am new to overclocking and would need someone's opinion and help with my problem. Please reply.
It seems to me that my CPU multiplier isn't stable at my Q6600 (Intel Quad Core). CPU-Z identifies a different multiplier( usually when CPU is fully loaded, it identifies it as should)(when it's at Idle the multiplier drops and all computer specs drop dramatically).
I have my CPU overclocked to 3.0ghz (original 2.4ghz), doesn't seem to be a hard clock speed to gain, with
CPU multiplier -x9.
Host clock Frequency -333.
CPU Voltage -1.325v (Default).
FSB -1.3v (Intel DX38BT board).
MCH Voltage -1.45v.
I also Have DDR3 Corsair RAM-1333mhz
-Didn't have to overclock it, but changed settings from AUTO to manual, to adjust it's frequency( had some problems running it on auto, so I just set it to a
manufacturer default manually)
-Memory Frequency -1333mhz
-Reference -333
-Voltage -1.7v
(9-9-9-24)
I do have a great cooling to my system and ran stability test for 8hrs with no change.
TEMPS ARE
-IDLE- ------ --- --- FULL-LOAD
core#0 -35 -------- core#0 -49
core#1 -30 -------- core#1 -45
core#2 -27 -------- core#2 -42
core#3 -27 -------- core#3 -40
THE Problem: My Multiplier is changing from x9 with Frequency at 333(3ghz) to x6 with same 333 frequency (2ghz)
It happens at all time- I run a lot of small programs and utilities to confirm this and it's been proved that Voltage stays the same at all times 1.325
and my TEMPs are the same.....but The whole computer's specs are down(when I'm at idle)
PLEASE help, comment ,etc...
THX
Message edited by Anonymous on 08-30-2008 at 11:03:59 PM
Related Product
Profile: stranger
More Information
This is the 8hrs stability testing...it shows the multiplier drop and ...
http://i497.photobucket.com/albums [...] 89/8hr.jpg
The normal Frequency...
http://i497.photobucket.com/albums [...] -Scr_2.jpg
The Drop...
http://i497.photobucket.com/albums [...] 9/DROP.jpg
Profile: stranger
More Information
I also found out that my old DELL -laptop has a same thing going on with it.
The multiplier drops from x15 to x6
I guess That it drops from MAX to minimum...
Is it fine at all...or am I paranoid
Profile: Forum Veteran
More Information
Check out the "C2D Not Running Full Speed / Wrong or Low Multiplier" sticky in the CPU section.
e2160@3GHz: OCing my way to Ubuntuland!
Profile: stranger
More Information
It could be a wrong multiplier, but I have searched a lot for the best one... and this setting looks like the best...I Have tried with a lot of settings starting from x6 to x9.....This is the best and most stable result I got....
However The FREQUENCY looks odd to me *(and as I said before my laptop has x15 multiplier dumps to x6...during CPU-Z analysis),...
Have no Idea what to do....
doesn't look any bad....but I don't want to screw it up and try to get best performance and best stability at my *first OC* .....
Specs at my first post would explain my settings....
More Information
Again, read the sticky I mentioned in my last post. It will explain what you are seeing.
Profile: old hand
More Information
Now where was that link to the flash film 'Posting and You'?
I believe now we can laugh at you... :P
Profile: stranger
More Information
you can probably..... xD
THX
Profile: stranger
More Information
One question-....-
Is there a way to adjust Speed Step ?
I mean to manually set when settings should kick in...?
Profile: stranger
More Information
There is a pic....with CPU speed...STRESS test and TEMPS
Guess that Temps are normal...?
http://i497.photobucket.com/albums [...] ablexD.jpg
it's a FULL-load
Message edited by Anonymous on 08-31-2008 at 12:33:11 AM
Profile: journeyman
More Information
Speedstep automatically kicks in when your CPU is idle, thus saving you energy. After all, you don't need all that processing power when you use the restroom for example, do you? But, you can disable it in BIOS if you really don't want it.
Profile: nimble knuckle
i wanna post 3 times in a row
yes you can disable it
although i wouldn't
I didn't do it
Profile: enthusiast
More Information
it's called speedstep and it's a function built into the q6600 that when the cpu sits idle it slows down on it's own, and your laptop has the same thing. As a matter of fact it started with the pentium m chips.
Did I hit you with a Mack Truck?
More Information
n°1773051
08-31-2008 at 06:45:16 PM
