G
Guest
Guest
Hi there,
I am going to build myself a water cooled PC, I quite new to this method, and would very much appreciate an experts opinion.
The CPU is a Intel Core 2 Quad Extreme Edition QX9650 "LGA775 Yorkfield" 3.00GHz 1333FSB……
And to keep it cooled I am thinking of using:
1 x XSPC RS360 120mm Radiator (attached to the top of Coolermaster RC-1100 case - http://www.twenga.co.uk/prices-Cosmos-S-COOLER-MASTER-PC-tower-case-411263-0)
3 Fans attached to Radiator (http://www.overclockers.co.uk/showproduct.php?prodid=WC-022-XS)
- Dimensions: 120 x 120 x 25mm
- Rated speed: 2200 RPM ±10%
- Air flow: 88.00 CFM
and water pump + tank: 750 lph:
(http://www.overclockers.co.uk/showproduct.php?prodid=WC-011-XS)
Do you think a single radiator would be enough? Would stacking 2 layers of 3 120mm fans onto the single radiator make much difference?
I have considered using external cooling methods, but wanted to try and keep all the cooling contained within the single case.
Many Thanks.
Many Thanks.
