Tom's Hardware Forums » CPU & Components » CPUs » CPU not running at full speed while stress testing.
Word :   Username :
Bottom
Author
 Thread : CPU not running at full speed while stress testing.
The only religion is Quantum Physics
Profile: journeyman
More Information
Hi lads!
I just got my PC to work! It's my first build, so i'm ever so happy!
My CPU is a E8400.
Anyhow, i downloaded some software, CPU-Z, Prime95 and CoreTemp.
And while running Prime95 i noticed that my CPU-Z recorded only around:
Core Speed 2671,5MHZ
multiplier set at x 8.0
rated FSB at 1333.6
Bus speed at 334.0mhz.
Volt at 1.192
Okay. I am aware of speedstep but since i'm stress testing it i assume that this will tell the CPU to work at full throttle! So what is the problem?
I havn't updated my Motherboard yet since i got it out of the box, could this have any influence?
I also have another quick question(s) :):
- how long should i be running prime95 (and which test would be suitable? (blend and so on)
- My temp wont raise above 49 while stress testing but my CPU heatsink is litteraly chillingly cold, i have to use midgets to touch it. Is this normal? (that the heat wont dispatch to the whole heatsink?). It's cold all over.
Cheers. And thanks! :)
Related Product
Neverending cycle - Build, Upgrade, Scrap, Repeat
Profile: enthusiast
More Information
I'm not too familiar with the E8400 but the first thing I see is the multiplier. Normally with Intel Core 2 CPUs its 9, and drops to 6 under speedstep, so check your bios to see if it's set to 9 normally.
Also, as far as what test you want to use depends on what you want to test. Typically errors show up in an hour or so but whenever I do an overclocking build I do 8-24+ hours (I ran my current build for 72 hours, overkill but I went away for the weekend unexpectedly)
A CPU below 50 with a cold heatsink means that everything's working properly and that heat's getting the hell out quickly :)
Profile: old hand
More Information
If you're running Vista, check your power management settings. Look at the processor settings, there will be a minimum and maximum setting (in %). If you are using a power saving plan the maximum will not be at 100% and therefore will not let the CPU run at full speed. If it is <100% change it and see if that solves your problem.
http://valid.x86-secret.com/cache/banner/376871.pnghttp://valid.x86-secret.com/cache/banner/327043.png
Profile: journeyman
More Information
Ah. Thank you both.
It was the multiplier! It's at 9x now, i don't know why it was set at 8x.
Also, i changed the power settings from balanced to High performance. . dunno if it changed anything but thank you for the notice.
Cheers
Profile: enthusiast
More Information
Are you running 2 instances of prime 95?
I recommend you switch to Orthos, its far easier to use and gets the same results.
get it here
http://sp2004.fre3.com/beta/orthos_exe_20060420.cab
Upgrading sig...
35% Done
Profile: journeyman
More Information
Well. . i'm in school now, and at home i'm running Prime95 at fourth hour.
I was wondering, does it stress test both cores in the dual core processor? or only one?
Anyhow, i choosed the setting blend in prime95 and i'm looking forward for the results. . I havn't seen the temp above 49. Even after i changed my CPU to 3ghz.
Profile: journeyman
More Information
2 instances of prime95?
Here's a multi-threaded version of prime95:
ftp://mersenne.org/gimps/p95v251.zip
Profile: journeyman
More Information
I'm only running one "instance" i think (sorry does this mean, like, one program of prime95? English is not my native language :)).
I just downloaded the newest version and ran the program in a blend test.
by the way, your link is not working (or maybe it's mozilla?).
Message edited by Moondrinker on 03-06-2008 at 01:04:58 PM
Profile: journeyman
More Information
uh well. . when i came back my computer had rebooted :S . . hmm
Google Ads
News
Taking AMD and Intel processors to the limit
Published on December 17, 2004
One year ago, an ambitious project at the Tom's Hardware Guide Lab set a world record of processor speed - 5.25 GHz. This year, the staff focuses on a real world stress test to highlight reliability and quality of the processors: Progress and results can be viewed in real time over the Internet. Read more
Dungeons and Dragons Online stress testing begins
Published on December 14, 2005
Lovers of the classic Dungeons and Dragons role-playing game will finally get a massively multiplayer online game. Dungeons and Dragons Online (DDO) will be undergoing stress testing this next week. The game is scheduled to be released in the first quarter of 2006. Read more
Tom's Hardware: GeIL DDR2 test samples faster than commercial devices
Published on April 12, 2006
The first pair of DDR2 modules has completed its test track in the latest edition of Tom's Hardware's Stress Test series. Read more
DRAM makers look to reduce DDR2 testing times
Published on January 10, 2006
Since late last year, several DRAM makers have begun requesting that testing houses cut their DDR2 memory testing times by 20-40% amid cost concerns, according to sources. Read more
Latest Reviews & Articles
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
1,000 GB: Three Samsung TB Drives
Published on September 23, 2008
Storage vendors split the desktop hard drive market into performance, mainstream, and energy-efficient products. We looked at Samsung’s Spinpoint F, the RAID version and the EcoGreen F to discover how a 1,000 GB drive differs from another. Read more
