Help, My Sata DVD Burner Not detected
mathias15t
5
I purchased a dvd burner and to my surprise it was a Sata. Deciding not to return it for a refund i decided to buy a Bi-directional Ide - sata adapter heres a link to what i got.
http://www.digitalet.com/Items/ada-sy-bir-idesa-bp?&caSKU=ada-sy-bir-idesa-bp&caTitle=3.5%22%20Bi-Directional%20IDE%20to%20SATA%20or%20SATA%20to%20IDE%20Adapter
I plugged it in tried both switches And Nothing!
it states that its compatable with optical drives but no luck. Any Ides?
i am looking for some drivers but no luck.
mathias15t
5
yeah i did i figured out the problem its that the adapter was smaller than the outlining plastic so i had t be very precise when plugging it in or else i would miss 2 of the prongs
