Tom's Hardware > Forum > CPU & Components > CPUs > D820 Heat Problem
D820 Heat Problem
Forum CPU & Components : CPUs - D820 Heat Problem
Hi,
My old PC uses Intel Pentium D D820 (2.8GHz) processor on a Gigabyte GA-945GM-S2 Motherboard. The CPU is over 60c even at idle. It gets nearly 70c at load. So I got a Gigabyte 3D Rocket cooler which helped to reduce the heat by 5c. I have used thermal paste as advised in Toms forums. The heat sink get very hot that its hard to touch even. I tried removing side panels of my casing but it didn't help either. Any advices, suggestions welcome...
thanks.
------------------------------ E6550@2.80GHz, ASUS P5K, ASUS EAH4870 512MB, Kingston 4GB (PC2-6400) , SAMSUNG HD322HJ 320GB x2, Creative SB Audigy Value, Creative Inspire M5500 5.1,COOLER MASTER eXtreme Power RP-650-PCAR 650W
Sponsored Links
Pentium D's, especially the 8xx series, are known to be very hot. Mine (820 too) idles at 48 and goes around 65 at 100%. Its not necessary a reason to be concerned. Your temps are a little high but your CPU may work just fine.
Reply to Paul_gren
Thanks Paul_gren,
Are U using the stock cooler. Mine started spinning at around 4500rpm so the noise was unbearable. Same with U?
Reply to umeshnk
no not the stock cooler...i use a Thermaltake golden orb 2. I keep it at 1300 rpm with a fan controller and its almost inaudible.
im planning to change it to a E8400 as soon as it becomes available (coz at the moment there is little to none available).
much more power for much less heat.
hope i helped u
Reply to Paul_gren
There are 980 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
